I am currently editing vob files of old sci-fi dvds. However there are lots of dirt, scratch etc. WB simply dumped all the episodes without doing any basic editing, such as cleaning the films or cleaning the whatever mm reels free of dust etc.
So far i am making progress and restoring dvd to better quality output but cleaning each episodes is rather time consuming. The amount of flickering is staggering. Currently using virtualdub2, avidemux, photoshop with topaz plugins, avisynth (a pain to learn), topaz gigapixel and video enhance (to output lossless tiff files), staxrip, handbrake.
Film Dirt Cleaner (FDC) plugin for virtualdub2 is doing the most of the cleaning. However when there is a scene change, the last frame before scene change and the first frame after scene change doesn't get cleaned. FDC requires comparison of previous and next frame for the present frame to be cleaned or not. Therefore last frame before scene change and the first frame after scene change makes FDC unworkable.
Using virtualdub2 I can go from one scene change to another but then I to type out the frame numbers in notepad++ of frames that require cleaning in photoshop. This is very time consuming.
Is there a way to output all the frame numbers of all scene changes automatically to a txt file. I have been searching for a week and do not think anyone ever thought of creating this potentially time saving software/plugin whatever. Virtualdub2 is somewhat 3/4 of the way there.
Results 1 to 19 of 19
There are several avisynth variations on writefileif (txt file) and scenechange detection in these threads
https://forum.doom9.org/showthread.php?p=1678941
https://forum.doom9.org/showthread.php?t=168697 -
Ok I have added mvtools2.dll, DePan.dll, DePanEstimate.dll and tried your first link and tried both Scene Detection Using MVTools2 and Scene Detection Using Depanestimate and both gave an error - AviSource: Could not decompress frame 0.
This is over my head.
AVI file is
Format : AVI
Format profile : OpenDML
File size : 10.8 GiB
Duration : 42 min 5 s
Overall bit rate : 36.8 Mb/s
Writing library : VirtualDub2 build 44282/release
Video
Format : FFV1
Format version : Version 3.4
Format settings, GOP : N=1
Codec ID : FFV1
Bit rate mode : Variable
Bit rate : 36.8 Mb/s
Width : 1 024 pixels
Height : 576 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossless
Bits/(Pixel*Frame) : 2.495
Stream size : 10.8 GiB (100%)
coder_type : Range Coder
MaxSlicesCount : 4
ErrorDetectionType : Per slice -
I use XviD via VirtualDub for this (yes, that old MPEG4 Codec that nobody uses anymore).
I just let it run a 1st pass of a 2-pass encode and it'll generate a tidy text file during that first pass containing all the scene changes it found. You can also alter the threshold if needed.
I needed this a couple of times for touching up subtitles; to find subtitles that are leaking just a few frames across a scene change because that's a big no-no in subtitles. -
If you wanted to get FDC, or other processes that require frame-1 and frame+1 as well as frame0 to fully work, you could always cheat by temp pre-adding dupes of the edge frames (e.g. new subclip = old subclip w dupe of 1st frame prepended & dupe of last frame appended) then, post-process remove those extra frames. Lots of extra scripting, but doable.
Scott -
BUt if you add before the first frame that you want to clean, a duplicate frame that has the same "spot", than the temporal filter cannot remove the defect, or am I missing someting?
Did you uncomment out the writefileif line ?
"#" is a comment symbol in avisynth - it means ignore the line . ie. write nothing.
You preview the script and adjust the thresholds when the writefileif line is commented out - so you can see if the scenechange detection is correct. If threshold is too high or too low - you might miss some scenechanges, or get false positives. Then when you want the actual file with the adjusted correct threshold, you uncomment out that line to write the file -
This is the script so far.
#Script to find scene changes
Loadplugin("C:\Program Files (x86)\AviSynth\plugins64+\mvtools2.dll")
filename = "E:\currser\BABYLON5\new\scenes.txt"
BlockChangeThresh = 350 # Default: 350. Increase to reduce number of scenes detected;
# Determines whether a block has changed from prev frame.
Num_blocks_changed = 90 # Default: 90. Increase to reduce number of scenes detected;
# How many changed blocks (given threshhold) must change to trigger scene change
source=FFVideoSource("E:\currser\BABYLON5\new\Soul Hunter.avi").AssumeTFF().killaudio().colorYUV(auto gain=true) #add this to increase contrast
source_fields=source.convertTOYV12(interlaced=fals e)
source_super = source_fields.MSuper(pel=2, sharp=0)
backward_vec = MAnalyse(source_super,isb = true, delta = 1, blksize=16,search=0)
SceneChange = MSCDetection(source_fields, backward_vec,thSCD1=BlockChangeThresh,thSCD2=Num_b locks_changed)
#Uncomment following line for troubleshooting. It puts the scene change threshold numbers on the screen.
ScriptClip(source_fields,"Subtitle(String(AverageL uma(SceneChange ) ),align=5)")
#This line writes frame numbers to file. These can be imported into Vegas or other editor
WriteFileIf(source_fields,filename, "(AverageLuma(SceneChange)>20)" , "current_frame+1", flush=false)
When # is put back in on the last line I can see the video showing the scene change. When I remove # the frame numbers doesn't come up. I pressed vdub forward scene button and the frame numbers start to appear.
How exactly am I suppose to operate the script? Is it automated or do I need to constantly do something? -
For any of the writefileif variations (scenechange detection or otherwise) , you can use open the avs in vdub/vdub2 and use file=>run analysis pass and it will write the text file
You can comment out the script clip line as per the instructions when you're ready to write the actual text file . You toggle one or the other. Scriptclip is just to overlay the information (so you can "see") so you can debug and get more accurate values. -
OK done that.
What does AverageLuma(SceneChange)>20 do?
Also the scene change between live frame and the next fade out frame isn't detected. Anything i can do?
BlockChangeThresh = 200 # Default: 350. Increase to reduce number of scenes detected;
Num_blocks_changed = 60 # Default: 90. Increase to reduce number of scenes detected;
source=FFVideoSource("E:\currser\BABYLON5\new\Soul Hunter.avi").killaudio().colorYUV(autogain=true) #add this to increase contrast
ScriptClip(source_fields,"Subtitle(String(AverageL uma(SceneChange)),align=5)")
#WriteFileIf(source_fields,filename, "(AverageLuma(SceneChange)>50)" , "current_frame+1", flush=false)
You had Subtitle(String(AverageLuma(SceneChange) ),align=5)") is the space between ) ) important? -
On that version, Use the debug mode with ScriptClip to overlay the info . Use that information to adjust values of BlockChangeThresh or Num_blocks_changed until you get ideal values for your source . It tells you can increase or decrease the value to detect more or less scenes in the comments
The next frame is written when that threshold value is surpassed. So if you have >20 , then when it prints value >20 , it will write
current_frame+1 on the text file when writefileif is enabled
Fades can be difficult to categorize, if you include them and it's a slow fade, you're going to get a lot of false positives (scene change frame number printed, when it shouldn't be) . eg. if a camera moves from a shadowy corridor to a lit corridor, that resembles a type of fade.
You're supposed to preview the script and adjust the values before you write the text with writefileif - because each source is different, different types of movies, content, styles of scene changes
If mvtools2 detection is not ideal for a particular source, you can try dozens of other variations. Some might be more accurate than others for a given source. But none will be perfect for everything
Also, he has coloryuv(autogain=true) in that version
You might try disabling that if you wanted to include fades, because that could interfere with a fade scene transition (it should brighten the darker frames more than the brighter frames during the fade) -
Ok my latest.
source=FFVideoSource("E:\currser\BABYLON5\new\Soul Hunter.avi").killaudio().colorYUV(autogain=false) #add this to increase contrast
backward_vec = MAnalyse(source_super, isb = true, delta = 1, blksize=16, search=0)
ScriptClip("subtitle(string(current_frame))")
ScriptClip("Subtitle(String(YDifferenceFromPreviou s),align=1)")
WriteFileIf(source_fields,filename, "(AverageLuma(SceneChange)>30)", "current_frame", """ ":" """, "current_frame+1", flush=false)
Last frame and first frame of scene change are printed out correctly using "current_frame", """ ":" """, "current_frame+1"
I have adjusted the settings to get the desired result. So far so good.
Just one more stumbling block. Close action is no good for FDC and they will show up like this series of numbers
19068:19069
19069:19070
19070:19071
19071:19072
19072:19073
19073:19074
19074:19075
19075:19076
Is there a way to group this to output to
19068:19076
Possible bug somewhere.
Run video analysis pass goes through the video to the end but the output stopped at 40000ish frames leaving 20000ish frames left to go. I pressed F5 key vdub script editor and then it finishes the job. -
Not sure with internal avisynth functions; maybe with some macro or other spreadsheet function. You can also ask at doom9
Are you commenting out ("#") and disabling the scriptclip lines for the actual writing runs ? scriptclip can cause memory and other issues
Did you try avsr64 (to rule out if it's vdub issue) ? It's slightly faster than vdub analysis pass, and it's easier to batch run concurrent instances (simultaneous execution of multiple scripts if you have enough memory/resources)
Code:avsr64 script.avs
Best way to split a file into many when you know the frame numbers
By crbd98 in forum EditingReplies: 6Last Post: 24th Mar 2021, 07:34 -
Adding numbers to output file names with YouTube-DLG
By Hakunamatata67 in forum Video Streaming DownloadingReplies: 6Last Post: 18th Jun 2020, 03:32 -
Find out frame numbers for qp files
By Valit in forum Newbie / General discussionsReplies: 7Last Post: 13th Feb 2020, 12:57 -
Why frame numbers in VirtualDub and Avisynth different?
By Megafox in forum Newbie / General discussionsReplies: 5Last Post: 15th Sep 2018, 11:56 -
Display Optional Frame Numbers?
By jfharper in forum EditingReplies: 3Last Post: 8th Feb 2017, 23:38
