Results 1 to 10 of 10
  1. First of all, I'm not very good at FFmpeg and capturing.
    so... I am trying to record capture card source using ffmpeg below.
    ffmpeg -f dshow -pixel_format yuyv422 -rtbufsize 18000k -video_size 1920x1080 -framerate 29.97 -i video="[my capture card]":audio="[my capture card audio source]" -pix_fmt yuv420p -c:v h264_nvenc -flags +ilme+ildct -x264opts tff -b:v 12000k -maxrate 22000k -profile:v high -preset veryfast -c:a aac -b:a 192k -y output.ts
    I want to capture it top field interlaced video. but it is fixed bff. I tried many times with other many options but It's always fixed as bff.
    I want to force tff, please help me how to do it..
    Thank you for helping and reading. have a nice day
    + I added the ffmpeg logs. Please check
    +i added ffmpeg log
    ffmpeg -f dshow -pixel_format yuyv422 -video_size 1920x1080 -framerate 29.97 -i video="capturecard":audio="capturecard" -f nut -vf "fieldorder=tff" -vcodec rawvideo - -loglevel panic | ffmpeg -i - -pix_fmt yuv420p -vf "fieldorder=tff" -flags:v +ildct+ilme -x264opts tff=1 -top 1 -rtbufsize 20000k -c:v h264_nvenc -b:v 12000k -minrate 12000k -maxrate 22000k -profile:v 2 -preset 1 -c:a aac -b:a 192k p7.ts
    ffmpeg version 4.4-full_build-www.gyan.dev Copyright (c) 2000-2021 the FFmpeg developers built with gcc 10.2.0 (Rev6, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libglslang --enable-vulkan --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 56. 70.100 / 56. 70.100 libavcodec 58.134.100 / 58.134.100 libavformat 58. 76.100 / 58. 76.100 libavdevice 58. 13.100 / 58. 13.100 libavfilter 7.110.100 / 7.110.100 ffmpeg version 4.4-full_build-www.gyan.dev Copyright (c) 2000-2021 the FFmpeg developers libswscale 5. 9.100 / 5. 9.100 libswresample 3. 9.100 / 3. 9.100
    libpostproc 55. 9.100 / 55. 9.100 built with gcc 10.2.0 (Rev6, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libglslang --enable-vulkan --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 56. 70.100 / 56. 70.100 libavcodec 58.134.100 / 58.134.100 libavformat 58. 76.100 / 58. 76.100 libavdevice 58. 13.100 / 58. 13.100 libavfilter 7.110.100 / 7.110.100 libswscale 5. 9.100 / 5. 9.100 libswresample 3. 9.100 / 3. 9.100 libpostproc 55. 9.100 / 55. 9.100
    Input #0, nut, from 'pipe:': Metadata: encoder : Lavf58.76.100 Duration: N/A, start: 0.000000, bitrate: N/A Stream #0:0: Video: rawvideo (YUY2 / 0x32595559), yuyv422, 1920x1080, 29.97 tbr, 59.94 tbn, 59.94 tbc Metadata: encoder : Lavc58.134.100 rawvideo Stream #0:1: Audio: vorbis (oV[0][0] / 0x566F), 44100 Hz, stereo, fltp Metadata: encoder : Lavc58.134.100 libvorbis
    Codec AVOption x264opts (x264 options) specified for output file #0 (p7.ts) has not been used for any stream. The most likely reason is either wrong type (e.g. a video option with no video streams) or that it is a private option of some encoder which was not actually used for any stream.
    Stream mapping: Stream #0:0 -> #0:0 (rawvideo (native) -> h264 (h264_nvenc)) Stream #0:1 -> #0:1 (vorbis (native) -> aac (native))
    Output #0, mpegts, to 'p7.ts': Metadata: encoder : Lavf58.76.100 Stream #0:0: Video: h264 (High), yuv420p(tv, progressive), 1920x1080, q=2-31, 12000 kb/s, 29.97 fps, 90k tbn Metadata: encoder : Lavc58.134.100 h264_nvenc Side data: cpb: bitrate max/min/avg: 22000000/0/12000000 buffer size: 24000000 vbv_delay: N/A Stream #0:1: Audio: aac (LC), 44100 Hz, stereo, fltp, 192 kb/s Metadata: encoder : Lavc58.134.100 aac
  2. The capture device determines whether to capture tff or bff. If you want tff from your bff capture device you need to convert it yourself. I don't know the ffmpeg filters for this but what you want to do is separate the fields, discard the first one (a bottom field), then weave the fields back together.
  3. Instead generic ffmpeg flags use x264 dedicated flags -
    something like (just example for "x264opts"):
    @SET x264opts="qp=16:qpmin=8:level=4.1:ref=0:bframes=0:no-chroma-me=1:subme=2:open_gop=0:keyint=1:tff=1:interlaced=1:bluray_compat=1:pic_struct=1:aud=1:nal_hrd=vbr:force_cfr=1:cabac=0:no_psnr=1:no_ssim=1:colorprim=bt709:transfer=bt709:colormatrix=bt709:stitchable=1:no-psy=1:scenecut=0:no-deblock=1:aq-mode=0"
    @ffmpeg.exe -c:v libx264 -preset:v ultrafast -tune:v fastdecode -profile:v high -x264opts %x264opts% -x264-params %x264opts%
  4. Originally Posted by pandy View Post
    Thank you for helping. I tried this but it doesn't work... TT
  5. You're using -c:v h264_nvenc , but -x264opts
    use -c:v libx264 instead of -c:v h264_nvenc
    You have -pixel_format yuyv422 and -pix_fmt yuv420p
    If the device is sending 4:2:2 , and you want to convert it to 4:2:0, you're doing it in a progressive manner. This will result in interlaced chroma artifacts. You would need to set the sws flags to interlaced scaling when downscaling the chroma
    Instead of -pix_fmt yuv420p; use -vf scale=interl=1,format=yuv420p
  6. Originally Posted by jagabo View Post
    Thank you for reply. I am trying this now... It is so hard... actually I Cant understand this 100% lol anyway thank you
  7. Originally Posted by poisondeathray View Post
    Thank you for replay. I tried like below
    ffmpeg -f dshow -pixel_format yuyv422 -rtbufsize 18000k -video_size 1920x1080 -framerate 29.97 -i video="capt card":audio="cap card" -vf scale=interl=1,format=yuv420p -c:v libx264 -x264opts qp=16:qpmin=8:level=4.1:ref=0:bframes=0:no-chroma-me=1ubme=2pen_gop=0:keyint=1:tff=1:interlaced=1:bluray_compa t=1ic_struct=1:aud=1:nal_hrd=vbr:force_cfr=1:cabac=0: no_psnr=1:no_ssim=1:colorprim=bt709:transfer=bt709 :colormatrix=bt709titchable=1:no-psy=1cenecut=0:no-deblock=1:aq-mode=0 -g 15 -flags +ilme+ildct -top 1 -b:v 12000k -minrate 12000k -maxrate 22000k -preset 1 -c:a aac -b:a 192k -y p7a.ts
    I literally pasted above pandy's x264 opts. and changed nvenc to x264.. but it was still output the bottom field.
    I dont know what is the problem : <
  8. -vf setfield=tff
    -vf setfield=tff,scale=interl=1,format=yuv420p
    But if your card sends actual BFF, then it will be jerky for playback - True content BFF order, encoded and flagged TFF.
  9. Originally Posted by poisondeathray View Post
    -vf setfield=tff
    OMG IT WORKS. I CAN'T BELIEVE IT. THANK YOU SOOO SO SOOO MUCH. I don't know What is actually jerky btw.
    It is so magical. I love you guys Thank you
  10. Originally Posted by poisondeathray View Post
    good point, my fault.
    Not sure on nvenc capabilities - if possible thread author should provide what ffmpeg is capable on this.
    ffmpeg -h encoder=h264_nvenc >h264_nvenc.txt
    Not sure what is supported and what is not supported - have no NVidia HW so unable to verify.
