Merge with Lossless Cut resulted in frozen frames in playback.
Results 1 to 11 of 11
The site said processing, without any mention of lossless. Assumed it must of re-encoded.
Is clever Ffmpeg-GUI a cleaner option than TMPGEnc MPEG?
Read that TMPGEnc MPEG will make small changes at joins.
When searching MPEG-4 Visual (DivX 5) you only find results for MPEG-1/2.
Is MPEG-4 DivX 5 another format not native for all software listing MPEG-1/2?
Seems confusing.
I want to keep the exact original format to maintain original file history. -
Other segments are exactly the same if required.
General
Complete name : C:\Users\1\Desktop\video\video01.mpg
Format : AVI
File size : 3.93 MiB
Duration : 41 s 328 ms
Overall bit rate : 798 kb/s
Writing library : VirtualDub build 13720/release
FileExtension_Invalid : avi
Video
Format : MPEG-4 Visual
Format settings : BVOP
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : DX50
Codec ID/Hint : DivX 5
Duration : 41 s 120 ms
Bit rate : 784 kb/s
Width : 360 pixels
Height : 288 pixels
Display aspect ratio : 5:4
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.302
Stream size : 3.84 MiB (98%)
Writing library : DivX 5.0.0 (UTC 2002-03-04)
Audio
Format : MPEG Audio
Format version : Version 2.5
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Bit rate mode : Constant
Bit rate : 8 000 b/s
Channel(s) : 1 channel
Sampling rate : 8 000 Hz
Stream size : 40.4 KiB (1%)
Alignment : Split across interleaves
Interleave, duration : 73 ms (1.82 video frames)
Interleave, preload duration : 394 ms -
Seems like it's an .avi file rather than .mpg, perhaps you should rename it
I was also wondering about that, are we certain that the file should be changed.
Once before I found problems the way this program and premier read file data? -
Rename the files to avi.
Did you try Avidemux to join (file/append) the files? There is a portable version here if you don't want to install it
https://www.videohelp.com/software/AviDemux
If it's doesn't work post the actual files here -
Virtualdub replies cannot locate decompressor for 'DX50' (unknown).
Will try avidemux and extension change.
Lossless Cut works with the extension change to avi, best solution I have found.
ThanksLast edited by Tom4; 11th Jul 2021 at 21:52.
Right way to join MPG files?
By yetanotherlogin in forum Video ConversionReplies: 19Last Post: 29th Sep 2019, 10:08 -
Re-encoding DV to DV - quality loss?
By Xoanon in forum RestorationReplies: 9Last Post: 22nd Jul 2019, 09:30 -
quality loss with DVDStyler?
By QueenAllTheWay in forum Authoring (DVD)Replies: 5Last Post: 20th Feb 2019, 22:39 -
Help to improve visual quality of vhs
By Altruo in forum RestorationReplies: 19Last Post: 10th Jun 2018, 01:22 -
Join or Combine 2 AVI files with no quality loss.
By deadnuttz in forum EditingReplies: 18Last Post: 21st Sep 2016, 03:09
