Results 91 to 119 of 119
Not totally sure atm.
(haven't had time to do enough testing)
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Another new scenario for me. This one is Progressive, but suffers from blending frame. So I assume the only thing needed here is SRestore? as I don't need to De-interlace or TFM it?
SRestore 25 or 23.976 didn't yield good enough results. SRestore 23.976 fix some problem in other sections of the video, but not here. Thanks! -
That video has too much blending for SRestore to work well. If you use it to reduce the frame rate to 12 or 12.5 fps you may get rid of most of the blending in the character animation but the panning shots will be noticeably jerky/flickery.
I'm pretty sure I prefer the blending over jerky/flicker video. Will stick with SRestore 23.976 and it fixed a lot of the other problem, and the rest - it is what is is. Thank you
Does anyone know what exactly in QTGMC cause the jerky movement (QTGMC.mp4)? As this is progressive, I'm using QTGMC for cleaning up the bad capture and de-noising. I found it more effective than calling santiag(), and that QTGMC() + SMDegrain() has better results then just SMDegrain():
But it doesn't matter which preset I'm using, the end results are jerky, compared to when I use the exact script without QTGMC (without_qtgmc.mp4). Also attaching the source.SRestore(25)
QTGMC(Preset="Faster", Inputtype=2)
Thanks as always!
Your source was originally progressive but has been through an NTSC to PAL conversion with field blending. You can't call SRestore() while the frames are still interlaced. And since the video has field blending you need to double frame rate deinterlace before calling SRestore(). And the correct frame rate is 24 or 23.976, not 25.
Code:AviSource("source.avi") AssumeTFF() QTGMC(preset="faster") SRestore(23.976) -
Thank. That indeed solved the problem. But why the current frame rate is 23.976? I'm planing the same part one by side, and the 23.976 is more jerky compared to the 25.
I'm seeing the opposite. At 25 fps the output contains a duplicate every 25 frames -- creating an obvious jerk every second. Note that SRestore() can take a while to lock into a pattern. So the first second or so of a clip may not be as smooth as the rest.
It's possible I have something else in the script that cause that. I will try your minimal example above when home.
There's something I have been thinking about yesterday. When I ripped and post-processed DVDs back at the day (they were 30FPS NTSC DVDs), the recommendation was to use TFM(). That would mostly lead to a 3-2 pull-down TDecimate() would clean it up.
On all the VHS material (the Cartoons really) I worked with, I never used TFM(), and I never seen any pull-down. The results after bobbing was either 1 movement per frame, and then I would just QTGMC(FPSDividor=2), or 2 movement per frame, means the content is progressive and there's nothing I need to do with it. On some cases, De-interlacing would have blended frames, so I would use SRestore.
Is TFM just Bober? when should it be used on the VHS captured content (if it should be used at all)? -
Cartoons are never animated at 50 fps or 60 fps. On film they almost always have character animation at 12 fps and panning shots at 24 fps. When converted to NTSC video they are usually go through 3:2 pulldown. When film is converted to PAL video it is often sped up to 25 fps. Cheap PAL productions often start with analog NTSC video tape that goes through a standards converter that resizes the frame and adds field blending to convert 59.94 fields per second to 50 fields per second. That's much cheaper than going back to the original film (which often doesn't exist anymore anyway) and digitizing it.
TFM is a field matcher. It starts with one field of a frame, then looks at the previous field and next field to see which leads to the least combing. With film sources one of those fields will match with no comb artifacts. Sometimes there is still some combing because a field is orphaned (or a bad capture, or some other problem). If it finds residual combing it deinterlaces the areas with comb artifacts (you can disable this if you want with the pp option).
You can interleave two calls to TFM() to bob a video. The simplest form it looks like this:
Depending on whether the frames are TFF or BFF you may need to reverse the field values.Code:Interleave(TFM(field=0), TFM(field=1))
But this is only useful in some special circumstances. -
Thank you for the professional answer as always
So I'm trying to connect the dots in here. The Cartoons on the DVD were indeed non-interlaced 30FPS, and you can easily see the 3-2 Pull-Downs on the Source file. The way we handled it back then was:
The TDecimate part is clear. It takes the 3-2 pull down, and It Decimate the duplicated frames, so it will end up with 1 movement per frame on panning shot.TFM().TDecimate()
But the original video was already 3-2, so why we call TFM() and the TDecimate() and not TDecimate() directly?
Now, the VHS captures - are interlaced cartoons at 25FPS. Post QTGMC de-interlacing, they are at 50FPS, and that's as you mention is the wrong FPS. The way I "Solved" it is by using FPSDivisor=2 (or SRestore for blended frames). This end up with 1 movement per frame again on panning shots.
So am I'm right to assume I will not be using TFM() on interlaced content? TFM() is only used for non-interlaced content where there's pull-downs? -
Source.avi in post #96 is interlaced PAL. After QTGMC().SRestore(25) it still has a duplicate frame every 25 frames. So you need to SRestore to 24 fps, not 25 fps.
So what would be the TFM().TDecimate(cycle=25, cycler=1)
So would that:
Be exactly like that:QTGMC(preset="faster")
SRestore(23.976)
?QTGMC(preset="faster")
TFM().TDecimate(cycle=25, cycler=1) -
QTGMC + Denoise + sRestore to 12 + frame interpolation to 24 -> not smooth
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Which Denoiser are your using here (and which settings), and which frame interpolation you used? (ie. Can you please post your script
I had a 2nd read on all this thread (now after multiple videos under my belt) and tried to summarize everything. Mostly for my future-self, other readers, and to confirm with you I understand everything correctly. Note everything below is specifically for cartoons.
I think that's about it.1. Find a panning shot, and walk it frame by frame. If every 2nd frame has a combing effect to it, It means it's interlaced video. Another way to verify it, is to run "Yadif(1)" (adjust TFF/BFF Accordingly) and the results should be one movement per frame. If you see blended frames post Yadif, it means the video is frame blended.
2. If every frame has combing in it, It means it's phase-shifted.
3. If you see no combing at all, It's progressive.
Now, how to handle each of the scenario:
1. If the video is interlaced, de-interlace it using QTGMC, and bring it back to either 25 or 24 using SRestore. Check which one doesn't leave any jagged panning.
2. If Video is interlaced and frame-blended, do the same - use SRestore 25 or 23.976.
3. If it's phase-shifted, TRM() it.
4. If Video is progressive, check that during the panning shot, there is movement every 1 frame. If that not the case, check the pattern. 3:2 for example, means you need to run TDecimate(), if the 25th frame is duplicated, use TDecimate(cycle=25, cycler=1), etc. If you see blended frames, use SRestore like you do with interlaced.
The only question I still trying to find answers for, is:
1. Why on the DVD Cartoons we worked on, we used TFM().TDecimate(), instead of just TDecimate() (those cartoon were progressive, NTSC, and I see no differences between using TDecimate() and TFM().TDecimate()).
2. When the cartoon is interlaced, and has no blending frames. Is SRestore the right way to down it back to 25/24? Or perhaps I should use something else like AssumeFPS?
Thanks! -
Didn't keep the script used QTGMC preset=Fast, DPIR as deblocker/denoiser iirc mit strength 30, sRestore defaults aside from frate, and Rife with anime model for the frame interpolation.Which Denoiser are your using here (and which settings), and which frame interpolation you used? (ie. Can you please post your script ).
So the script probably looked like:
This was just a quick test to how much frame interpolation would help or not, I did not fine-tune any of the filters.Code:# Imports import os import sys import ctypes # Loading Support Files Dllref = ctypes.windll.LoadLibrary("I:/Hybrid/64bit/vsfilters/Support/libfftw3f-3.dll") import vapoursynth as vs # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'I:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/FrameFilter/RIFE/RIFE.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/libtemporalmedian.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/GrainFilter/AddGrain/AddGrain.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/DenoiseFilter/NEO_FFT3DFilter/neo-fft3d.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/DenoiseFilter/DFTTest/DFTTest.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/EEDI3.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/ResizeFilter/nnedi3/NNEDI3CL.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/libmvtools.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/temporalsoften.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/scenechange.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/fmtconv.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll") # Import scripts import G41Fun import adjust import havsfunc # source: 'C:\Users\Selur\Desktop\Source.avi' # current color space: YUV422P8, bit depth: 8, resolution: 720x576, fps: 25, color matrix: 470bg, yuv luminance scale: limited, scanorder: top field first # Loading source using FFMS2 clip = core.ffms2.Source(source="C:/Users/Selur/Desktop/Source.avi",cachefile="E:/Temp/avi_57f7b5c99d1dc57d9f89d294923ed1fa_853323747.ffindex",fpsnum=25,format=vs.YUV422P8,alpha=False) # making sure input color matrix is set as 470bg clip = core.resize.Bicubic(clip, matrix_in_s="470bg",range_s="limited") # making sure frame rate is set to 25 clip = core.std.AssumeFPS(clip=clip, fpsnum=25, fpsden=1) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # setting field order to what QTGMC should assume (top field first) clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=2) # Deinterlacing using QTGMC clip = havsfunc.QTGMC(Input=clip, Preset="Fast", TFF=True, opencl=True) # new fps: 50 # make sure content is preceived as frame based clip = core.std.SetFieldBased(clip, 0) from vsdpir import DPIR # adjusting color space from YUV422P8 to RGBS for vsDPIRDeblock clip = core.resize.Bicubic(clip=clip, format=vs.RGBS, matrix_in_s="470bg", range_s="limited") # deblocking using DPIRDeblock clip = DPIR(clip=clip, strength=30.000, device_index=0) # adjusting color space from RGBS to YUV444P16 for vssRestore clip = core.resize.Bicubic(clip=clip, format=vs.YUV444P16, matrix_s="470bg", range_s="limited") # adjusting frame count and rate with sRestore clip = havsfunc.srestore(source=clip, frate=12.000, omode=6, speed=9, thresh=16, mode=2) # Color Adjustment clip = adjust.Tweak(clip=clip, hue=0.00, sat=1.30, cont=1.00, coring=True) clip = G41Fun.SpotLess(clip=clip) # cropping the video to 688x564 clip = core.std.CropRel(clip=clip, left=16, right=16, top=6, bottom=6) # adjusting color space from YUV444P16 to RGBS for vsRIFE clip = core.resize.Bicubic(clip=clip, format=vs.RGBS, matrix_in_s="470bg", range_s="limited") # adjusting frame count&rate with RIFE clip = core.rife.RIFE(clip, model=2) # new fps: 24 # adjusting output color from: RGBS to YUV420P10 for x265Model clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10, matrix_s="470bg", range_s="limited") # set output frame rate to 24.000fps clip = core.std.AssumeFPS(clip=clip, fpsnum=24, fpsden=1) # Output clip.set_output()
Thanks Selur! Might be a good introduction to Vapoursynth
Yea, sorry. I forgot to mentioned post #107 is after some research I did including the original source.avi file.Definitely not the same as you can easily verify with your "source.avi" of post #96 -
No. First of all, TDecimate(Cycle=25, CycleR=1) would reduce the frame rate from 50 fps to 48 fps. You would need TDecimate(Cycle=25, CycleR=13) to reduce it to 24 fps. Secondly, SRestore() preferentially removes blended frames, whereas TDecimate() preferentially removes duplicate frames. The latter will retain many more blended frames.
Thanks again everyone! So I assume that if no one correct the summary I posted above, It's correct
So if there's not blended frames after de-interlacing, there's no difference between using SRestore(25) and AssumeFPS(25)?Secondly, SRestore() preferentially removes blended frames, whereas TDecimate() preferentially removes duplicate frames. The latter will retain many more blended frames. -
Hehe, OK. Fair enoughThere was so much wrong with it that I didn't have the energy to correct it all.
Thanks everyone! -
I'll start with point #1
If you see progressive frames like that during motion the video likely isn't fully interlaced, it's more likely telecined from a progressive source. But, sometimes with analog caps, a field is missed during capture and the previous field is used again. Those frames will appear progressive because both fields are the same. But that wouldn't normally be in a regular pattern like you describe here.
Yes. That indicates interlaced video.
It could be frame blended or field blended. If you see pairs of identical (deinterlacing artifacts aside) blended frames it's frame blended. If you see some frames with blending, others not, it field blended.Last edited by jagabo; 17th Aug 2021 at 17:22.
As a side note: Frames might also just appear progressive if none or mainly vertical motion is happening. So make sure to look at horizontal movement,..
I'll start with point #1Thank you for clearing it out for me.As a side note: Frames might also just appear progressive if none or mainly vertical motion is happening. So make sure to look at horizontal movement,..
It's better trying to understand the concepts rather than trying to establish sets of rules which may fail with the next video sourceVideo, is hard.I agree. The OP doesn't seem to have grasped the fundamentals.
I was but 8 years old, when people moved from CRTs to LCD. And just until a year ago - when my father asked me to digitize the family camcorder footage, I knew nothing of video. I have to learn which VHS hardware I should/shouldn't use, set up VirtualDub with the proper settings, figure out which video format to use, and how to make it smaller, how to properly archive videos, what's AviSynth is, what QTGMC means and the list just goes on and on. Every step I do forward, I also have to move downwards as more information unfolds. For non-professionals, reading the Wiki page Telecine is complex. There's a lot the page expected your to know, and you need to keep reading other sources. On top of that, there isn't much information about those things online. You won't be finding a YouTube channel, or even a blog explaining when to use TFM(). I assume that's because the analog technology is disappearing from the world. I also suspect there's not a lot of professional people who really know the technology out there those days. So in this sense, this forum is a gold-mine.
So it's left for the casual user to learn by reverse engineering, and that's what I did up until now. Posting a video, getting answers, drill into those answer, asking more questions, trying things. And that's something leads to errors. Your right to mentioned I'm not familiar with the concept. Being familiar with the concepts, requires a LOT of investment. I am getting there, but as a hobbyist, It's happening slow. So the easiest way, at least for me - to keep pushing forward, was to extract logic, by examples.
That's being said, I completely understand the lack of energy the walk-me-through and correct my errors. Especially as I'm asking a lot of questions
And I understand that if I want to get better at that, I have to invest more time with the fundamentals. Anyhow, I appreciate any person helping another person over the internet, and I thank you nevertheless.
IVTC on recorded tv - tdecimate() getting hung up on channel logo overlay
By FrankWDoom in forum Video ConversionReplies: 2Last Post: 13th Oct 2020, 13:07 -
TDecimate scrip problem
By kalemvar1 in forum Video ConversionReplies: 4Last Post: 14th May 2020, 13:35 -
Quick question on TIVTC's Tdecimate
By attackworld in forum Newbie / General discussionsReplies: 4Last Post: 11th Mar 2019, 15:05 -
TDecimate vs. Srestore?
By Vitality in forum DVD RippingReplies: 11Last Post: 19th Jan 2019, 19:13 -
QTGMC and TDecimate as a custom IVTC script?
By Vitality in forum RestorationReplies: 9Last Post: 22nd Nov 2018, 16:04
