I have an MKV that has Russian and French audio tracks and it also has English and German image-based (dvd_subtitle) tracks. I want to hardcode the English subtitle track. I know how to do this with text-based tracks, but, I am getting various errors when I try to hardcode the image-based track. I have been able to export the English track to a SUP with Handbrake. But, I get errors either using the track directly from the MKV or importing the SUP.
Here are some examples that I found online and have tried :
These commands give me the error message (the subtitle track I want is stream #0:3): "Error initializing output stream 0:3 -- subtitle encoding currently only possible from text to text or bitmap to bitmap"Code:ffmpeg -i in.mkv -map 0 -filter_complex "[0:v][0:s]overlay[v]" -map "[v]" out.mkv ffmpeg -i in.mkv -map 0 -vf "subtitles=in.mkv:stream_index=0" out.mkv
I am trying to do this in ffmpeg. I realize that some other apps may be able to do this, but, I believe that most/all are based on ffmpeg - so I should be able to do this with an ffmpeg command. Ultimately I want to keep only one audio track and eliminate the two embedded/soft subtitles - which I already know how to do.
Also, I would like to convert the MKV to an MP4, but, I don't think that the command(s) I would use would be any different.
Any ideas?
Results 1 to 24 of 24
Try
This should burn in the first subtitle in in.mkv into out.mkv (if image based), without audio (can be muxed afterwards)Code:ffmpeg -i in.mkv -map 0:v -map 0:s:0 -filter_complex "[0:v][0:s:0]overlay[v]" out.mkv
That command generates the error: "Filter overlay has an unconnected output"
When I do this command:It generates the error (BTW, stream #0:2 is the second audio track): "Error initializing output stream 0:2 -- Subtitle encoding currently only possible from text to text or bitmap to bitmap"Code:ffmpeg -i in.mkv -map 0:v -map 0:s:0 -filter_complex "[0:v][0:s:0]overlay[v]" -map "[v]" out.mkv
General Unique ID : 21430015959520753467612615379059835278 (0x101F455C9EA18935E49B6DDD14D9818E) Complete name : in.mkv Format : Matroska Format version : Version 2 File size : 1.02 GiB Duration : 1 h 36 min Overall bit rate : 1 503 kb/s Movie name : Encoded date : UTC 2015-11-30 06:45:49 Writing application : mkvmerge v5.1.0 ('And so it goes') built on Feb 1 2012 11:32:58 Writing library : libebml v1.2.2 + libmatroska v1.3.0 Attachments : Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Muxing mode : Header stripping Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 36 min Nominal bit rate : 1 200 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.116 Title : Writing library : x264 core 120 r2151 a3f4407 Encoding settings : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=2 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=1200 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Audio #1 ID : 2 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 1 h 36 min Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : 80 ms Title : Language : Russian Default : Yes Forced : No Audio #2 ID : 3 Format : AAC LC Format/Info : Advanced Audio Codec Low Complexity Codec ID : A_AAC-2 Duration : 1 h 36 min Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 SPF) Compression mode : Lossy Delay relative to video : 80 ms Title : Language : French Default : No Forced : No Text #1 ID : 4 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Title : Language : English Default : Yes Forced : No Text #2 ID : 5 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Title : Language : German Default : No Forced : No -
ffmpeg -i in.mkv -map 0:v -map 0:s:0 -filter_complex "[0:v][0:s:0]overlay[v]" -c:s dvd_subtitle out.mkv
ffmpeg -i in.mkv -map 0:v -map 0:s:0 -filter_complex "[0:v][0:s:0]overlay[v]" -c:s:0 dvd_subtitle out.mkv
Then try
Code:ffmpeg -i in.mkv -map 0:v -map 0:s:0 -filter_complex "[0:v][0:s:0]overlay[v]" -map "[v]" -c:s:0 dvd_subtitle out.mkv
This ran and did not generate an error. This is the mediainfo for out.mkv:
What I see when I view out.mkv in VLC:Code:Unique ID : 100830054107533089207352341002486193295 (0x4BDB297C1BA825198B84A99FD17A9C8F) Complete name : out.mkv Format : Matroska Format version : Version 4 File size : 1.09 GiB Duration : 1 h 36 min Overall bit rate : 1 619 kb/s Movie name : Writing application : Lavf58.78.100 Writing library : Lavf58.78.100 ErrorDetectionType : Per level 1 Video #1 ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 36 min Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Title : Writing library : x264 core 161 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No Video #2 ID : 2 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L6.2 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Width : 400 pixels Height : 422 pixels Display aspect ratio : 0.948 Frame rate mode : Constant Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : Lavc58.136.100 libx264 Default : No Forced : No Color range : Full Matrix coefficients : BT.470 System B/G FILENAME : random_image.jpg MIMETYPE : image/jpeg Video #3 ID : 4 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 36 min Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Writing library : x264 core 161 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Default : No Forced : No Text ID : 3 Format : VobSub Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 1 h 36 min Title : Writing library : Lavc58.136.100 dvdsub Language : English Default : Yes Forced : No
- the audio tracks are missing (you still have not told me why you want to do that)
- two video tracks were added, but, they have no functionality
- the first (English) subtitle track is still there as a soft/embedded but not hardcoded subtitle
- the second subtitle track was removed
So, still not right
ffmpeg -i in.mkv -filter_complex "[0:v:0][0:s:0]overlay[vid]" -map "[vid]" -c:s:0 dvd_subtitle -c:s:1 copy -c:a copy out.mkv
This is the mediainfo after that command:
Viewing it in VLC, this is what I see:Code:General Unique ID : 66492593406954912071231035078641825036 (0x320601F6CEDC5FA1124AAD02C1D5B50C) Complete name : out.mkv Format : Matroska Format version : Version 4 File size : 559 MiB Duration : 1 h 36 min Overall bit rate : 808 kb/s Movie name : Writing application : Lavf58.78.100 Writing library : Lavf58.78.100 ErrorDetectionType : Per level 1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 1 h 36 min Bit rate : 792 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.076 Stream size : 548 MiB (98%) Writing library : x264 core 161 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=18 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Default : Yes Forced : No
- the audio tracks have been removed
- there is only one video track
- the English subtitle track is hardcoded into the video
- there are no selectable subtitle tracks
So, that did everything I wanted with the video and subtitles, but, there is no audio. -
ffmpeg -i in.mkv -filter_complex "[0:v][0:s:0]overlay[v]" -map "[v]" -map 0:a -map 0:s:1 -c:a copy -c:s copy out.mkv
Viewing out.mkv in VLC, this is what I see:
- both audio tracks are there
- there is a single subtitle track that is German
So, that did not leave just the one audio track and it left a subtitle track.
Looking back at the various commands I have tried, it seems that the -filter_complex" switch does not play nice with "map" processing. This video is large enough that it is taking me about 15 minutes to run each test because of the re-encoding of the video. I am working on it now and will get back with my findings. Feel free to post another try. Thanks for your help.Last edited by the_steve_randolph; 13th Jul 2021 at 01:47.
To keep only the first audio stream and no subtitle stream use:
To keep only the second audio stream and no subtitle stream use:Code:ffmpeg -i in.mkv -filter_complex "[0:v][0:s:0]overlay[v]" -map "[v]" -map 0:a:0 -c:a copy out.mkv
The stream numbering of ffmpeg is different from that of mediainfo.Code:ffmpeg -i in.mkv -filter_complex "[0:v][0:s:0]overlay[v]" -map "[v]" -map 0:a:1 -c:a copy out.mkv
To see the correct stream numbering of ffmpeg, just enter the following:
WE HAVE SUCCESS!!!!!
Just to recap for future readers of this thread:
The video I have is:- an MKV
- no "disc" titles
- no chapters
- the first audio track is Russian
- the second audio track is French
- one video track
- the first embedded subtitle track is English (image-based dvd_subtitle)
- the second embedded subtitle track is German (image-based dvd_subtitle)
What I want to do is:- only use a single ffmpeg command (the version I am using here is: N-101923-gc012f9b265)
- remove the Russian audio track
- hardcode the English subtitle track onto the video
- remove both embedded subtitle tracks
My computer is running updated Windows 10 Pro, Intel Core i9 7940x, 64GB RAM, GEForce GTX1070, and, I am executing the ffmpeg command in a CMD window.
The successful command is:
Converting to MKV lost the "frame width" and "frame height" metadata tags, but, they are not lost when converting to an MP4. In successive efforts I have added "-crf 18" to retain the original quality, assigned a new name to the kept audio track, and, assigned a new name to the "title" metadata tag. The tricky part was making the audio-naming tag of the kept track since I was removing the original audio track #0. I can't make HandBrake do all of that, which is just one of the reasons why I wanted to do all of this in a single ffmpeg command. Here is that command:Code:ffmpeg -i in.mkv -filter_complex "[0:v][0:s:0]overlay[v]" -map "[v]" -map -0:a:0 -map 0:a:1 -sn out.mkv
A big thanks to ProWo for all of the help and patience, and, aCode:ffmpeg -i in.mkv -filter_complex "[0:v][0:s:0]overlay[v]" -map "[v]" -map -0:a:0 -map 0:a:1 -sn -crf 18 -metadata:s:a:0 title=French -metadata:s:a:0 language="" -metadata title="My Title [1974]" out.mp4
to Selur
FFMPEG and new GPU-based YADIF_CUDA deinterlacer
By hydra3333 in forum Video ConversionReplies: 25Last Post: 6th Mar 2019, 12:33 -
Need help with missing text in image based subs due to distortion
By Concept in forum SubtitleReplies: 2Last Post: 6th Feb 2019, 16:39 -
How to change a single subtitle image in a PGS subtitle file??
By Gregostus in forum SubtitleReplies: 8Last Post: 14th Nov 2017, 01:26 -
Just an idea: ffmpeg based key frame accurate cutting,...
By Selur in forum Newbie / General discussionsReplies: 30Last Post: 21st Mar 2017, 03:56 -
Problem with Embedded DVB subtitle tracks
By criggs in forum SubtitleReplies: 3Last Post: 14th Oct 2016, 17:06
