Hi
I have a .m2ts file containing an interlaced AVC stream. After cutting parts, I convert it using x264vfw codec, with --tff option. The problem is the result is slightly jerky : every one second or so, there's a little jerk visible on slow regular moves.
The frame rate is left untouched (25FPS).
The Display Renderer Statistics menu (ctrl + j) of MPC-HC says "1 frame drop every 0.50 seconds".
What could be the reason?
Thanks for your help.
	There are probably dozens of possible reasons. You need to provide a sample of your source (not reencoded) and an encoded video made from that source.
	Hello
 I cropped 10s of the original video using tsMuxeR GUI to provide you with a short extract. I encoded it using the same settings I used for the whole video. And then, surprise : no more jerks. Then I tried the same with the whole video remuxed : still no jerks.
 It seems the remux step fixes something wrong in the original video, and finally this is no surprise as the video is a digital TV recording.
 I always remux the M2TS file to MKV before using VirtualDub (as some M2TS frames have a problem when displayed within VirtualDub), but this MKV remux step doesn't prevent the jerks.
 So I didn't find the reason of the original bug, but a way to circumvent it.
 Thank you!Last edited by GD314; 10th Jul 2021 at 21:00.
  [FFMPEG] Non-Interleaved AVI in ConcatenateBy giroro in forum EditingReplies: 9Last Post: 27th Feb 2020, 06:39
  Staxrip "Jerky Playback" After Encoding a VideoBy deepfrayder in forum Newbie / General discussionsReplies: 19Last Post: 12th Nov 2019, 00:50
  Jerky Video playBy ro2124 in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2019, 06:52
  HD to SD encoding with DGindex/Avisynth/VirtualDubBy TheSuperBeanie in forum Newbie / General discussionsReplies: 8Last Post: 30th Mar 2018, 00:08
  encoding with ffshow but virtualdub encoderBy marcorocchini in forum Newbie / General discussionsReplies: 23Last Post: 31st Oct 2016, 04:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
