I have inserted bt709 video into avisynth and for some reason it shows artefacts around edges. What might be causing this?
Too much/poor compression in the source. Is that a 1:1 pixel display? Or is it scaled? Scaling can cause rough edges too.
I have fixed the problem by using ffmpegsource instead of DirectShowSource
I didn't expect that. But generally, DirectShowSource should be used only as a last resort. Use FfmpegSource or LSMASHSource instead.
ffmpeg h265 and banding / blocking artefacts
By marco000 in forum Video ConversionReplies: 3Last Post: 19th May 2023, 13:45 -
weird interlacing/deinterlacing artefacts
By phelissimo_ in forum Video ConversionReplies: 11Last Post: 1st Jan 2021, 09:57 -
Removing MPEG2 compression artefacts from commercial DVDs?
By Master Tape in forum RestorationReplies: 38Last Post: 17th Aug 2020, 17:27 -
MPC - HEVC 2160p - artefacts with NVIDIA CUVID
By asdrewq in forum Software PlayingReplies: 3Last Post: 24th Nov 2017, 11:06 -
Capturing and correcting PAL-speed audio of 24fps film without artefacts
By chen lung in forum Capturing and VCRReplies: 10Last Post: 6th Jun 2017, 16:33
