hi
i have a bush dvd2004 dvd player is there a way i can hook it up to my vcr/tv so when i play a dvd/vcd i can tape it at the same time i`ve tried scart on dvd toscart vcr rf out on video to rf on tv nothing
thanx
You won't be able to record DVD on a tape recorder because of macrovision protection.
The video signal out of dvd is corrupted to put scope video input stage out of sync.
The only way is to have a TV that re-output the input signal after reformating it. You can connect the player to the TV input and get the output to the scope.
Good luck -
There are devices you can buy which will allow you to do this, or maybe you can have your player chipped to remove macrovision (if you are in the UK try Multimod)
Don't seem to be getting anywhere. How to connect pc to dvd recorders
By xtube in forum Newbie / General discussionsReplies: 2Last Post: 11th Aug 2010, 22:26 -
Connect VCR/DVD Recorder to PC which has TV Tuner
By Butch1942 in forum Media Center PC / MediaCentersReplies: 1Last Post: 16th Feb 2009, 20:03 -
New DVD/VCR players NOT able to directly connect to cable line.
By jbitakis in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2007, 23:56 -
How to Connect VCR to ATI 650
By jshapard in forum Capturing and VCRReplies: 0Last Post: 22nd Sep 2007, 12:18 -
Best VCR OR VCR/DVD COMBO for restoration
By demonwarrior in forum Newbie / General discussionsReplies: 7Last Post: 24th Aug 2007, 03:02
