Can someone compile https://github.com/Lypheo/vs-placebo from source and share a Windows 64bit build?
Sadly the current release doesn't support the 'shader_s' parameter which was added after the release and reading that 'This repository has been archived by the owner. It is now read-only. ', I doubt a new release will be provided by the author.
Thanks!
Cu Selur
I hope you find a highly-skilled nerd who can do that job...
I did try to compile the g0ddämn thing, but
because the typical Linux devilopers are too lazy to redistribute the source-code of the small-sized dependencies,
(namely: libp2p and libplacebo), I did not succeed
"Programmers are human-shaped machines that transform alcohol into bugs." -
Thanks for trying.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Hmmm this is not just about some small-sized requirements, unfortunatly. I ended up downloading the vulkan api stuff thats about 500mb+ but still failed to build it on windows
Is there somewhere I can download FFMPEG with x264 for Windows 7 64bit?
By Livingonvideo in forum Newbie / General discussionsReplies: 2Last Post: 16th Jan 2020, 19:13 -
Need help to compile Youtube-dl on Windows platform
By skizzino in forum Video Streaming DownloadingReplies: 0Last Post: 30th May 2019, 12:37 -
DV Capturing problem with Windows 7 64Bit
By freak2010 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 21st Feb 2018, 09:34 -
How to Compile C Code FFmpeg Tutorial on Windows?
By nothingnew in forum Newbie / General discussionsReplies: 0Last Post: 7th Aug 2017, 04:14 -
is this MSVCR120.dll for windows 32 or 64bit?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 6th Nov 2016, 10:04
