  1. i have 100's of media files. i want to generate media info based on file name. like 1.mkv=>will contain 1.txt, abc.mkv=>abc.txt
    i am not sure how can i do that but here is one thing i tried. generate all mediafile into one text file. problem is it's not scanning the .mkv files. however if i set absolute path it's working like C:\ABC.mkv. i tried "*.mkv" and without ""
    not working:
    @ECHO off
    MediaInfo "*.mkv">a.txt
    PAUSE
    working:
    @ECHO off
    MediaInfo "C:\aa.mkv">a.txt
    PAUSE
    any help please?
  2. load files for mediainfo in loop:
    for %%a in ("*.mkv")  do ...
  3. For all MKV files in a folder:
    for %%F in ("*.mkv") do "g:\program files\mediainfocli\mediainfo" "%%~dpnxF" >"%%~dpnF.txt"
    For all MKV files in a folder and subfolders therein:
    for /R %%F in ("*.mkv") do "g:\program files\mediainfocli\MediaInfo.exe" "%%~dpnxF" >"%%~dpnF.txt"
    For MKV and MP4 all files in a folder and subfolders therein:
    for /R %%F in ("*.mkv" "*.mk4") do "g:\program files\mediainfocli\mediainfo" "%%~dpnxF" >"%%~dpnF.txt"
    You might want to include the extension in the text file name in case you have both an mp4 and an mkv of the same video in the same folder.
    for /R %%F in ("*.mkv" "*.mk4") do "g:\program files\mediainfocli\mediainfo" "%%~dpnxF" >"%%~dpnxF.txt"
    Change the path to mediainfo cli as necessary for your system. Those all assume they are in a batch file. If you want to enter the commands directly in a CLI window change all the double percents to single percents.
  4. thank you all
    edit:
    any difference between ~dpnF.txt and %%~dpnxF.txt?
