  1. Hello All,
    I tried to add "first play" do my DVD. It works OK if the "first play" has no sound. When I add sound track on it then the disc can not be played!!
    It doesnt play neither on DVD stand-alone player nor on PC .. what have I done wrong?
    Maestro to create DVD
    Nero 5580 for buring
    Win2k + SP2
    Pioneer A03
  2. Do you get any error during compiling the project. Why do you use Nero, you can burn diretly from Maestro or you can make a DVD-image and burn it from VOB or ?Nero?.
    Isn't it your audio file the problem , is it 48khz? Has the same length as the video? Do you get any error during simuleting the project. Has the mpeg2 correct timecode ( if you used CCE to encode it), does it starts with 00 or 01?
  3. Ok I'll double check .. I did create this clip using Premiere6. Video and
    audio have exact the same length, then CCE to convert to DVD mpg2 compilant stream.
    I'll check it once more time (create this clip again) then I'll post ..
    Thanks for replying :-)
    Jun 2001
    Also, I think the audio stream has to either be in PCM or AC3 format. I don't think that an MP2 audio stream will work.
