Hope this is the right place. I'm trying to capture old home videos using the Elgato Video Capture device. It works great for stuff I have already transferred to VHS, but trying to capture from the camcorder the picture is only in black and white. I have no idea what, if anything, I can do to fix it. Be grateful for any help. Thanks.
Results 1 to 9 of 9
As stated, black and white display is typical of NTSC tape played on PAL equipment.
But if you are certain that PAL does not come in to the equation then I suggest you provide the following
1. The make/model of your camcorder
2. Confirm that the tapes were recorded with this camera
3. Advise of the connection and cable used from the camcorder to the Elgato and any settings on the camera for video out.
4. Advise of the software you are using for capture and all settings of the software. -
1. It's an RCA Pro8 camera from the early 1990s
2. Definitely recorded with it, it's the only camera I've ever had that these tapes fit.
3. Using RCA cables (think that's what they're called) - the ones with the red, white and yellow connectors. The camera only has 2 ports though, white & yellow.
4. I'm using the Elgato video capture software with the default settings. -
I found a manual for a RCA Pro8 model 807 which does not have any peculiarities for playback or transfer to vcr (capturing would be the same process)
So do check that your 'default settings' do show composite signal and NTSC
Of course also check that your video (yellow) cable is correctly attached to the camera. It is, of course, possible that the connector at the camera end is at fault.
You might also wish to try other capture software such as AmarecTv. No settings required for this. If picture is still in B&W then you know something is clearly amiss. -
Indeed, If everything is connected and set up as it should the chroma circuitery in your camcorder is gone bad and it's time for another camcorder.
Hi8 to PC video is black and white
By MPvnX in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 23Last Post: 4th Feb 2021, 10:51 -
Black (no data) recording when capturing video from mini-DV camcorder
By Iskren in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 10th Jan 2021, 00:59 -
Capturing VHS, Black/White on PC
By Dutchsteammachine in forum Capturing and VCRReplies: 13Last Post: 20th Aug 2020, 10:29 -
Is there any software out there that automatically converts Black and White
By R.STEED in forum Video ConversionReplies: 77Last Post: 4th Nov 2017, 18:41 -
Capturing black and white video
By SHutson in forum Capturing and VCRReplies: 2Last Post: 10th Dec 2016, 16:03
