Results 1 to 9 of 9
  1. If i select "View=>Text" i can get follow screen, is there any template available for this output?
    Screenshot
    https://forum.videohelp.com/images/imgfiles/ZXJQ2wd.png
    this is the app i using:
    https://mediaarea.net/en/MediaInfo
  2. Member DB83's Avatar
    Jul 2007
    Not really a template. It is a generated report from the elements of the media that is reported and varies according to the media.
    However the generated report, I guess, takes the titles from "program files/mediainfo/plugin/language". Here you will see a csv file for each supported language of the utility. English being en.csv
  3. is there anyway i can get the all keyword which mediainfo generate?
  4. Member DB83's Avatar
    Jul 2007
    Don't really understand where you come from.
    Mediainfo generates the keywords (titles as I put it) that are specific to the media (It can add a couple depending on the source). But there is no point in attempting to add more (some options, but not text-mode, are editable) if it can not parse anything meaningful from the media.
    But if you mean something different then do try to explain yourself more clearly.
  5. thank you for the reply, i was looking for media info parameters which i able to find.
    however i guess there is no mediainfo default generate template. probably inbuilt.
  6. To get all available parameters that mediainfo can provide:
    @echo off
    SETLOCAL
    echo video mediainfoCLI
    set "mediainfo=C:\tools\Mediainfo CLI\Mediainfo.exe"
    set "temp_folder=C:\Temp"
    if not exist "%temp_folder%" MD "%temp_folder%"
    "%Mediainfo%" --Info-Parameters > "%temp_folder%\parameters.txt"
    START  "notepad.exe" "%temp_folder%\parameters.txt"
    ENDLOCAL&exit
    set mediainfo variable where is your Mediainfo.exe file located on your PC
  7. sorry, you want result for a video:
    "%mediainfo%" "my_mkv.mkv" > "mediainfo.txt"
    to get all txt files for all mkv's in a folder:
    @echo off
    SETLOCAL
    for %%a in ("*.mkv")  do call :get_mediainfo_text "%%a"
    endlocal
    echo DONE & pause
    goto :eof
    :get_mediainfo_text <video file>
    "%mediainfo%" "%~1" > "%~n1.txt"
    did not test it, but hopefully there is not syntax mistake
  8. if you want custom print , I guess that is what you want you can base it on this:
    https://forum.videohelp.com/threads/377677-Video-batch-files#post2468981
  9. thank you all, really appreciate.
