  1. Banned
    Jan 2021
    PAL
    I've only ever inserted MPEG2 and avi low standard definiton videos into avisynth. How do I insert h264 files?
  2. Use a source filter that supports the container and codec. Like LSMASH or ffmpeg.
    http://avisynth.nl/index.php/LSMASHSource
    http://avisynth.nl/index.php/FFmpegSource
    Basic usage:
    LSMASHVideoSource("filename.mp4") # only for mp4 or mov files
    LWlibavVideoSource("filename.mkv") # other file types
    ffVideoSource("filename.mkv")
  3. if you have an NVIDIA gpu, DGDecNV might be another alternative.
  4. Banned
    Jan 2021
    PAL
    Basic usage:
    Thank you
  5. Banned
    Jan 2021
    PAL
    how to install FFMpegSource?
  6. Banned
    Jan 2021
    PAL
    nvm i found out
  7. Put the 64 bit ffms2dll, ffms2.lib and ffmsindex.exe in AviSynth's 64 bit plugins folder (plugins64+ folder if you're using AviSynth+), and/or, put the 32 bit versions of those file in AviSynth's 32 bit plugins folder (plugins+ folder if AviSynth+). Put the FFMS2.avsi file in both plugins folders.
