    Sep 2010
    Australia
    In HandBrake GUI, under the Video tab, inside the Extra Options edit box, if I enter this string: colorprim=smpte170m:transfer=smpte170m:colormatrix =smpte170m the Color primaries, Transfer characteristics and Matrix coefficients are all BT.601.
    If I enter colorprim=bt709:transfer=bt709:colormatrix=bt709, I get Primaries BT.601 PAL, Transfer BT.709, and Matrix BT.709.
    If I enter --colorprim "bt709" --transfer "bt709" --colormatrix "bt709", I get Primaries BT.601 PAL, Transfer BT.709, and Matrix BT.601.
    Can anyone tell me what string to enter to get all three set to BT.709, please.
  2. -color_primaries bt709 -color_trc bt709 -colorspace bt709
    Use clever FFmpeg-GUI, then you don't need to enter anything by hand.
  3. Originally Posted by barmah View Post
    That worked for me on a random source when I tried Handbrake GUI
    Default (blank)
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Color primaries : BT.709
    Matrix coefficients : BT.709
    Maybe some issues with your source ? The VUI parameters should be overriden by the commands
    Maybe old handbrake version ?
    Sep 2010
    Australia
    Thank you both #2 and #3, both those options worked.
