FFMPEG seems to slow down as it goes along processing a video. I was processing a video for about 10 minutes and it started out at about 3x speed and went down to about 2.5x by the end.
Specs:
i5-8600k
16GB RAM
2070 (although wasn't using GPU)
On an SSD
Seems to happen with any kindof script or instruction.
Isn't a CPU heat issue, never goes above 60 degrees and drops to 30 degrees 2 seconds after the program is finished.
Edit: Just noticed something else: it slows down a lot in the first 10 or so seconds. So it might starts at 10x and rapidly drop to 3.2x, and then it will slowly drop once it gets there.
Edit 2: Happens in Handbrake too. Don't have any other video programs to test really.
This can be normal - prediction of speed depends on overall complexity - at the end prediction is close to real...
Concatenate video in ffmpeg -> time stamps problem
By nsenada in forum EditingReplies: 0Last Post: 30th Jan 2020, 14:38 -
VSDC slows down my file after i've finished editing.
By casino998 in forum EditingReplies: 1Last Post: 27th Dec 2018, 22:18 -
ffmpeg cutting: how to get negative start time?
By Luke M in forum EditingReplies: 1Last Post: 25th Jul 2018, 11:00 -
How to add a time stamp below of a screen capture from a video in ffmpeg?
By Chemist116 in forum Newbie / General discussionsReplies: 11Last Post: 2nd Jun 2017, 15:08 -
which time parameter to be considered in video frame for -ss flag in ffmpeg
By db2t4 in forum Newbie / General discussionsReplies: 6Last Post: 26th Oct 2016, 08:14
