Recently I transferred several VHS-tapes containing concert-footage to MPEG-2-files. Most of the VHS-recordings have a playing speed that differ a bit (too slow/too fast) from the digital remastered audio recordings that are available on CD.
My plan is to correct the video playback speed to match the audio files that I ripped from CD, and then join both the video at the corrected playing speed & the ripped audio together.
How can I arrange this with minimal / no loss of video quality ?
I read about software packages, like Kernel Video Repair, dgpulldown, ProjectX, Avidemux and Womble MPEG Video Wizard. Would they do help me to complete this project ?
Greetings,
Jesse
				Results 1 to 14 of 14
	Thank you for your reply. I prefer to adjust the playing speed of the video to match the correct speed of the audio (if possible). Is there any software available to decrease or increase the video playing speed ?
	ProWo is right. It's much better to adjust the audio. It can be speeded up or slowed down keeping the same pitch.
 However, if you insist, DGPulldown can adjust the playing speed of the video without reencoding.
 If it's a live concert recording I'd say they're playing it at the correct speed already. The CD might be different but I don't see how you can call it more 'correct'. Besides, CD audio can't be used in DVDs as-is. You can't just replace what you have now with the CD audio.I prefer to adjust the playing speed of the video to match the correct speed of the audio (if possible).
	How far out is the sync?
 Would you notice it over the space of one song?
 Do you plan on making a dvd from the repaired video?
	@Manono, let me explain... The video-material that I transferred from VHS is footage that's unavailable through official ways until now. I'm an Elvis Presley-fan, and through the years I collected several videotapes with concert footage. On several of those tapes the playing speed isn't correct. I guess it has to do with the fact that those tapes have been copied many times before I obtained my copy. I would like to adjust the video playing speed, and then take the audio from a CDrip and add that to my video. After correcting the video I would like to make a DVD from the repaired video.
	Does the CD match the video (except for the slight speed difference) including all the gaps between songs, etc
	Yes, it does.
 I just noticed that Pinnacle Studio also contains options like 'Controlling speed with Time Remapping'. Does anyone have experience using that program to stretch video's ? Would Pinnacle Studio be the right software to do the job for me ?
	Pinnalcle Studio is not a software that gets much discussion in the forum, except in somewhat derisory tones
 when it is mentioned. Perhaps somebody familiar with it will chime in.
 Have you tried Avidemux? It does have a transform Change FPS filter that can
 slow down / speed up the video.
 The video would have to be re-encoded (lossless if possible), then when you encode to DVD later the frame rate will have to be re-adjusted
 back to 25 PAL DVD standard, but this will use a method that would not change the runtime. eg. DGPulldown, dup frames, blending, etc,etc
	As I mentioned, DGPulldown can do the job without reencoding. BUT, only if you want to slow it down, not speed it up.
 And the audio is in synch with those? And doesn't 'warble' from a varying speed?On several of those tapes the playing speed isn't correct.
 I see no reason to believe that whatever speed you make the video, with pulldown to have it play back at 25fps, the commercial releases of the songs will then line up with the adjusted video. That and, as I already mentioned, CD audio can't be used in a DVD as is. At the very least you'll have to adjust the sample rate. And, depending on how large the DVD video is, you might also have to convert it to AC3 audio. Both mean reencoding the audio.I would like to adjust the video playing speed, and then take the audio from a CDrip and add that to my video.
	Dgpulldown can slow the video? Never heard that before. Also the source is likely to be interlaced. This seems like an interesting project
  Match VHS colors to digital sourceBy blinkHQ in forum RestorationReplies: 3Last Post: 22nd Aug 2020, 18:31
  Speed up video to restore original playback speed?By nekrosoft13 in forum Video ConversionReplies: 6Last Post: 30th Nov 2019, 01:16
  [MPC-HC] Increasing/Decreasing playback speed causes choppy videoBy Zee530 in forum Software PlayingReplies: 6Last Post: 16th Jul 2019, 11:57
  How to speed up a .MKV to match YouTube Speed?By NukeyDoo in forum Video ConversionReplies: 2Last Post: 27th Jul 2017, 05:03
  Potplayer - Audio distortion when increasing playback speedBy Spansme in forum Software PlayingReplies: 0Last Post: 23rd Nov 2016, 11:54
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
