On the QTGMC Download page
It says this:
I understand the first sentence because I have a 64bit OS.Dfttest, FFT3DFilter and MVTools2 need the FFTW3 library (windows builds). On a 64-bit Windows OS, extract the 32-bit libfftw3f-3.dll. Make a copy of it and rename it as "FFTW3.dll". Place the files "libfftw3f-3.dll" and "FFTW3.dll" in the SysWow64 folder.
If you want to use the 64-bit libfftw3f-3.dll versions then extract the 64-bit libfftw3f-3.dll. Make a copy of it and rename it as "FFTW3.dll". Place the files "libfftw3f-3.dll" and "FFTW3.dll" in the System32 folder.
I don't understand the second sentence. To help me out, could somebody please answer these questions:
Is QTGMC 32 bit and QTGMC 64 bit one in the same, with the only difference being the 32-bit or 64-bit plugins for it?
I'm thinking of using 32-bit AVISynth so I can get access to Chromashift or the Flaxen VHS filter in Vdub 32bit.
If I want to use 32-bit AVISynth on my 64-bit OS, should I be doing the first sentence or the second sentence (or both) quoted above in regards to the FFTW3 library files?
What does the second sentence actually mean? Why would you "want to use the 64-bit libfftw3f-3.dll versions...".
Thanks a lot.
If you want to get the 32 bit subsystem working, put the files into \syswow64 as per the instructions.
QTGMC and other scripts are neither 32 or 64 bit, they work unchanged in both environments,
it's the plugins they call and the bitness of the host program that have to match, either 32 or 64 bit,
I used 32 bit myself for the longest time, but I've recently started to use 64 bit; to get mtmodes and Prefetch()
working properly (for the better performance) the 32 bit version didn't work - kept failing due to memory
issues. This is the limit of the 32 bit memory addressing scheme -
No it's the other way around, \windows\system32 is the 64bit system
Arh Ha! Now I comprehend. Thanks Dave.
I've now got both 32 and 64 running.
Qtgmc-GUI. A simple encoder for your Qtgmc scripts.
By ProWo in forum Video ConversionReplies: 17Last Post: 4th Mar 2023, 02:01 -
Help with QTGMC
By Xyena in forum Newbie / General discussionsReplies: 6Last Post: 22nd Sep 2020, 12:25 -
I think this just needs QTGMC...
By pooksahib in forum Video ConversionReplies: 2Last Post: 30th May 2019, 03:12 -
Help with QTGMC?
By attackworld in forum EditingReplies: 3Last Post: 26th Nov 2018, 21:57 -
Library of Congress video
By alanplamo in forum Newbie / General discussionsReplies: 2Last Post: 22nd Sep 2016, 16:27
