    Feb 2014
    Germany
    Hello People,
    i would like to use streamllink on my Android Tablet and that's how I started.
    1. Termux installed from the Playstore
    2. Vlc installed from the Playstore
    3. Termux started and then...>
    1. Update repositories
    $ pkg update
    2. Install required packages
    $ pkg install clang python
    3. Install and build streamlink
    $ pip install streamlink
    4. Install nano to edit .streamlinkrc
    $ pkg install nano
    5. Create and edit .streamlinkrc
    $ touch ~/.streamlinkrc
    $ nano ~/.streamlinkrc
    6. Paste the following config options into .streamlinkrc
    player=am start -n org.videolan.vlc/org.videolan.vlc.gui.video.VideoPlayerActivity -a android.intent.action.VIEW -d player-http
    7. Now save it by holding Volume-Down + o then close with Volume-Down + x
    when I enter the download command under Termux, i get the following error message?
    streamlink https://bit.ly/3wYttPd best -o video.mp4
    [cli][info] Loaded config from deprecated path, see CLI docs for how to migrate: /data/data/com.termux/files/home/.streamlinkrc
    error: No Plugin can handle URL: https://bit.ly/3wYttPd
    What is it? What should I do?
    Need your help please
    thanks
    hasomaso
    Jan 2021
    Argentina
    The video url is wrong. You must to indicate a direct link and some headers like referer and/or user agent.
    For example:
    streamlink --http-header "Referer=https://flowcdn.nl/" "https://img.flowcdn.nl/hls/59/,aqcmoe5nbcqjddhroiz2jwetqfdkdibk7tuis3szgahnziniqkeqaxupo3sa,.urlset/master.m3u8" best -o video.ts
    Feb 2014
    Germany
    works perfectly @ lfer94 Bro.
    thx
