    Nov 2011
    chicago
    ffplay -af "volumedetect" shows a max volume of 21.0 recommendation while ffmpeg shows a recommendation of 8.2db
    both programs are at the same version/levels. both run against the same input mvk file.
    The original file is notably low volume, so Id like to increase it. Any reason why the different numbers? Which number should I use?
    Mar 2008
    this filter in ffplay displays max and average volume.
    These levels are shown in the usual -dB notation
    Nov 2011
    chicago
    Correct. Using ffmpeg -i %1 -af "volumedetect" -f null NUL
    and
    ffplay -i %1 -af "volumedetect"
    with the same input file shows the same output levels in the usual -dB notation but with different output -dB values. WHY? Which is the correct?
    Mar 2008
    I get the same numbers
