I am aware there is a new version but it's confusing as hell to try and set it up because there is always some step I'm missing. Can anyone help me?
And if command line syntax troubles you just use one of the many gui's available such as TVDownloader.
Note that Windows 10 no longer allows you to "Open CMD Window Here" via Shift+RightClick.
https://www.thewindowsclub.com/how-to-open-command-prompt-from-right-click-menu
It's "Open PowerShell Window Here" now. But you can switch to CMD by typing CMD+Enter into the PowerShell Window once it's open. There's a Registry hack that restores the Open CMD Window Here context menu. You can also run command line exe's within the PowerShell window by putting .\ before the program name. Assuming your in the youtube-dl folder: ".\youtube-dl http://..." -
"Adding Youtube-DL to your PATH allows you to run the youtube-dl command from any command-line interface such as Command Prompt or PowerShell without needing to first cd into the directory where you installed Youtube-DL."
https://danclowry.com/blog/youtube-dl-windows-install/ -
create folder
in the folder add files
same directory /
youtube-dl.exe (download)
ffmpeg.exe (download for window)
ffplay.exe (same zip)
now create new file
1.txt
edit
type
youtube-dl --help --version --skip-download
pause
rem example
youtube-dl --convert-subs srt --all-subs --embed-subs --output "%%(title)s.%%(ext)s" "--
format=bestvideo[ext=mp4]+bestaudio[ext=m4a]/mp4" --version --skip-download https://www.youtube.com/watch?v=yOhGkZ4U4lI
pause
save file
rename 1.txt to 1.cmd
or
rename 1.txt to 1.bat
run 1
need help to download youtube vid (IMD, youtube-dl, streamlink not working)
By olli66 in forum Video Streaming DownloadingReplies: 6Last Post: 30th May 2022, 08:31 -
Youtube-dl help - set it to download the 1080p AVC1 version
By [ss]vegeta in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Feb 2021, 12:59 -
youtube-dlc downloaded from youtube without sound
By flannob in forum Newbie / General discussionsReplies: 1Last Post: 2nd Dec 2020, 07:47 -
Youtube-dl 720 YouTube Video Problem
By Tom Saurus in forum Video Streaming DownloadingReplies: 6Last Post: 16th Oct 2020, 19:18 -
Please teach me how to download videos from this site (MPD/dash stream)
By ConTroll in forum Video Streaming DownloadingReplies: 3Last Post: 1st May 2020, 02:14
