Hi all,
I've had a look around, and can't seem to find much on this. I have home movies which I want to back up to CD if possible. I know that 1 dv can take up to 15GB when captured, but all I looking for is some feedback on how you guys would approach this. As you can tell, I'm fairly new to this, Thanks in advance.
You have some kind of firewire card I guess. It has some kind of nle editor. I use Premier.
After you are finished with you edit work you can save your edited movie as a avi ( with the correct codec ). Load this avi into your favorit mpeg encoder end encode it as a VCD or SVCD or Mpeg 2. Or just use Avisynth to frameserve to the mpeg encoder.
I'm using VCDComposer to make a VCD or Impression DVD-Pro if I wanna make a DVD.
You can finde several tutorials here or at doom9.org.
home movie editing help
By sirromjay in forum Newbie / General discussionsReplies: 2Last Post: 19th Mar 2012, 16:42 -
Home movie question
By imemine in forum Newbie / General discussionsReplies: 0Last Post: 11th Jan 2011, 18:10 -
Home Movie conversion help
By franksvideos in forum Newbie / General discussionsReplies: 2Last Post: 1st Apr 2010, 09:36 -
Best way to copy Home Movie DVD
By quxote in forum Authoring (DVD)Replies: 3Last Post: 18th Jul 2009, 02:27 -
Home movie / Movie Creation Software
By ironape2 in forum EditingReplies: 3Last Post: 3rd Apr 2009, 08:28
