Hi! Need help, please
I need to convert video file in high resolution 1080p from my MacBook (or PC), to Sony HVR-M25U (this device has dv in which allows to use firewire for that), I don't understand how to send video from MacBook via firewire to Sony HVR, so that I don't loose quality, because at the moment I get strange artifacts like stripes and etc. through rca and s-video.
Thank you in advance!
I don't know about Mac but for PC I used Vegas Pro 13 with print to tape option, You can do DV or HDV, There is no lossless way, Videos have to be rendered to HDV 1440x1080i to comply with HDV format unless you happen to have the exact HDV files on hard drive and you just want to print them back to tape.
afaik the hvr-m25u is a mini-DV/HDV deck. it plays/records to 1080i/p mini-dv tape in HDV format. the only way to properly transfer the tape to a computer is over firewire. and the same applies to transferring from the computer back to the cam. firewire 400 not 800.
He is already using firewire, Have you read his post?
Capturing MiniDV/HDV Footage with Sony HVR-M15AU - Lots of Questions.
By ninlive in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 19Last Post: 2nd Jan 2021, 20:26 -
Capturing For Archival Purposes - MiniDV/HDV
By ninlive in forum Capturing and VCRReplies: 1Last Post: 23rd Sep 2020, 03:35 -
deciding on laptop to best capture minidv , Hi8 and HDv video tapes
By peterellen in forum Capturing and VCRReplies: 5Last Post: 24th Apr 2020, 05:32 -
Lost frames/packets when transferring HDV footage from MiniDV via Firewire
By guy24s in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 4th Mar 2019, 02:55 -
How to transfer minidv video tapes to digital videos
By OldViddy in forum User guidesReplies: 6Last Post: 4th Dec 2016, 10:54
