Hello everyone!
I was trying to figure out if is worth for me to buy the necessary gear to start making physical disk backups.
First obstacle, BD100 (BDXL) disks are too expensive, so for anything under ~50GB I'm fine, but I can forget about UHD movies.
So I thought about re-encoding them to fit a BD50 trying not to loose much quality. I did a little bit of research and experimented a little bit with vidcoder.
Second obstacle, encoding time. x265 software 2 pass slow takes too much time (15+ hours), I need the rig for other purposes, not to speak of the power consumption.
H265 NVENC slow takes ~1h which is affordable, but I know is not near the quality of software encoding. So I wanted to ask you about your opinion of the results I'm going to achieve with NVENC for UHD movies in 45GB.
In your experience, Is going to produce noticeable artifacts? What would you do in my position?
Thanks!
				Results 1 to 1 of 1
  X265 2PASS SLOW quality WAS achieved by NVENC HEVC (Staxrip)By Comparison in forum Video ConversionReplies: 37Last Post: 14th Jan 2022, 04:42
  Pascal NVENC vs X264/x265 testBy sophisticles in forum Video ConversionReplies: 25Last Post: 5th Mar 2019, 03:15
  HandbrakeCLI optimal settings for HEVC NVEnc vs x265By KDallas in forum Video ConversionReplies: 0Last Post: 15th Feb 2019, 21:33
  4K UHD x265 Editing using AviSynth (Grey Frames)By TheLastOfThem in forum EditingReplies: 2Last Post: 22nd Jan 2018, 19:08
  UHD rip with NVENC - Info requestBy RELEONE1946 in forum Newbie / General discussionsReplies: 4Last Post: 4th Nov 2017, 14:04
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
