Hi,
I have a mkv file where I need to choose the audio / subtitle stremas and set the favorite as default:
With this command I can choose the audio track that I like and make the first audio as default and work for audio but not work for subtitlesCode:ffmpeg.exe -y -i originale_ridotto.mkv -map 0:0 -map 0:1 -map 0:2 -map 0:5 -disposition:a:1 -default-forced -disposition:a:0 +default+forced -disposition:s -default -c copy prova.mkv
I have tried:
but in all case the stream 5 (subtitle) is always default. I like to copy multiple subtitles and remove all default.Code:-disposition:s -default -disposition:s:0 -default -default_mode infer_no_subs
Code:Text ID : 4 ID in the original source medium : 4613 (0x1205) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 min 16 s Bit rate : 38.8 kb/s Count of elements : 2306 Stream size : 25.0 MiB (4%) Language : Italian Default : Yes Forced : No Original source medium : Blu-ray
Thare is a way to disable all subtitles ?
Thank you !!
Results 1 to 17 of 17
Try (if stream 5 is the first subtitle):
Read:Code:ffmpeg.exe -y -i originale_ridotto.mkv -map 0:0 -map 0:1 -map 0:2 -map 0:5 -disposition:a:1 -default-forced -disposition:a:0 +default+forced -disposition:s:0 0 -c copy prova.mkv
https://ffmpeg.org/ffmpeg.html
Search for disposition -
You can do all of this in MKVToolNix within a GUI. Takes a few minutes. Just highlight the track you want as default and change the switch in the right hand panel for audio and subtitles. Untick any tracks you don't want and remux.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
After some testing I found out the following:
Ffmpeg marks each first stream type (video, audio, subtitle) automatically as default.
Only if there are multiple streams of the same type (audio, subtitle) the default status can be changed with the disposition option.
In the command
-map 0 -disposition: 0 -disposition:3 default -disposition:4 default
first instructs to use all streams of the source file (-map: 0); then all dispositions for all streams are cleared (-disposition: 0), then stream 3 is assigned default status (-disposition:3 default), then stream 4 is assigned default status.
If there is only one stream type, then it will automatically become default.Last edited by ProWo; 24th Jun 2021 at 07:07. Reason: typo
Thank you I have tried to copy another subtitle:
so now the subtitle are two but the first still always the default.Code:ffmpeg.exe -y -i originale_ridotto.mkv -map 0:0 -map 0:1 -map 0:2 -map 0:5 -map 0:6 -disposition:a:1 -default-forced -disposition:a:0 +default+forced -disposition:s:0 -default -c copy prova.mkv
Any suggest ? -
Show me all your streams layout of your originale_ridotto.mkv (g.e. video=0, audio1=1, audio2=2, subtitle1=3, subtitle2=4 and so on).
Then say me, what streams should be default and default+forced. -
Here the original file:
Code:General Unique ID : 271738250723206880376426206628838418733 (0xCC6EE2272DCE7B9E40251F781FB4A92D) Complete name : T:\Film\metadata\Originale_ridotto.mkv Format : Matroska Format version : Version 4 File size : 627 MiB Duration : 3 min 20 s Overall bit rate mode : Variable Overall bit rate : 26.3 Mb/s Writing application : Lavf59.3.100 Writing library : Lavf59.3.100 ErrorDetectionType : Per level 1 Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : V_MPEG4/ISO/AVC Duration : 3 min 20 s Bit rate mode : Variable Bit rate : 17.9 Mb/s Maximum bit rate : 38.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 654.329 FPS Original frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.013 Stream size : 11.4 GiB Language : English Default : Yes Forced : No Original source medium : Blu-ray Audio #1 ID : 2 ID in the original source medium : 4357 (0x1105) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 3 min 20 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 32 bits Compression mode : Lossy Stream size : 126 MiB (20%) Title : Stereo Language : Italian Service kind : Complete Main Default : Yes Forced : No Original source medium : Blu-ray Audio #2 ID : 3 ID in the original source medium : 4352 (0x1100) Format : DTS XLL Format/Info : Digital Theater Systems Commercial name : DTS-HD Master Audio Codec ID : A_DTS Duration : 3 min 20 s Bit rate mode : Variable Bit rate : 4 956 kb/s Channel(s) : 8 channels Channel layout : C L R LFE Lb Rb Lss Rss Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossless Stream size : 3.15 GiB Title : Surround 7.1 Language : English Default : No Forced : No Original source medium : Blu-ray Audio #3 ID : 4 ID in the original source medium : 4352 (0x1100) Format : DTS Format/Info : Digital Theater Systems Codec ID : A_DTS Duration : 3 min 20 s Bit rate mode : Constant Bit rate : 1 509 kb/s Channel(s) : 6 channels Channel layout : C L R Ls Rs LFE Sampling rate : 48.0 kHz Frame rate : 93.750 FPS (512 SPF) Bit depth : 24 bits Compression mode : Lossy Stream size : 983 MiB Title : Surround 5.1 Language : English Default : No Forced : No Original source medium : Blu-ray Audio #4 ID : 5 ID in the original source medium : 4353 (0x1101) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 3 min 20 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 32 bits Compression mode : Lossy Stream size : 125 MiB (20%) Title : Stereo Language : English Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Text #1 ID : 6 ID in the original source medium : 4613 (0x1205) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 min 16 s Bit rate : 38.8 kb/s Count of elements : 2306 Stream size : 25.0 MiB (4%) Language : Italian Default : Yes Forced : No Original source medium : Blu-ray Text #2 ID : 7 ID in the original source medium : 4608 (0x1200) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 min 18 s Bit rate : 39.0 kb/s Count of elements : 2498 Stream size : 25.1 MiB (4%) Language : English Default : No Forced : No Original source medium : Blu-ray Menu 00:00:00.000 : :Capitolo 01
and here the output file:
for audio I can easly select the default track that I like, but I don't need any default subtitle.Code:General Unique ID : 67639306270200332921399926552547186001 (0x32E2DB45F71E2832CB34170F8B165551) Complete name : T:\Film\metadata\finale.mkv Format : Matroska Format version : Version 4 File size : 76.0 MiB Duration : 3 min 20 s Overall bit rate : 3 189 kb/s Writing application : Lavf59.3.100 Writing library : Lavf59.3.100 ErrorDetectionType : Per level 1 Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L4@Main Codec ID : V_MPEGH/ISO/HEVC Duration : 3 min 20 s Bit rate : 17.9 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 654.875 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 10 bits Bits/(Pixel*Frame) : 0.013 Stream size : 11.4 GiB Writing library : Lavc59.1.102 libsvt_hevc Language : English Default : Yes Forced : No Color range : Limited Original source medium : Blu-ray Audio #1 ID : 2 ID in the original source medium : 4357 (0x1105) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 3 min 20 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 32 bits Compression mode : Lossy Stream size : 126 MiB Title : Stereo Language : Italian Service kind : Complete Main Default : Yes Forced : Yes Original source medium : Blu-ray Audio #2 ID : 3 ID in the original source medium : 4353 (0x1101) Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 3 min 20 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Bit depth : 32 bits Compression mode : Lossy Stream size : 125 MiB Title : Stereo Language : English Service kind : Complete Main Default : No Forced : No Original source medium : Blu-ray Text #1 ID : 4 ID in the original source medium : 4613 (0x1205) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 min 16 s Bit rate : 38.8 kb/s Count of elements : 2306 Stream size : 25.0 MiB (33%) Language : Italian Default : Yes Forced : No Original source medium : Blu-ray Text #2 ID : 5 ID in the original source medium : 4608 (0x1200) Format : PGS Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 min 18 s Bit rate : 39.0 kb/s Count of elements : 2498 Stream size : 25.1 MiB (33%) Language : English Default : No Forced : No Original source medium : Blu-ray Menu 00:00:00.000 : :Capitolo 01
If for example I play this file with VLC player I see the subtitles, while if I play other MKV files with subtitles using VLC player I don't see the subtitles.
My need is copy all the subtitles but I don't want see it when I play the movie, but only if I switch with the remote.
There is a way to do it ? -
If you have subtitles. at least one has to be default.for audio I can easly select the default track that I like, but I don't need any default subtitle.
You posted a mediainfo report; the stream numbering here is not the same as with ffmpeg.
To see the ffmpeg compliant numbering of the streams, you just need to open the video file with ffmpeg.
e.g. ffmpeg -i originale_ridotto.mkv -
sorry you have right:
Code:ffmpeg version 2021-06-16-git-604924a069-full_build-www.gyan.dev Copyright (c) 2000-2021 the FFmpeg developers built with gcc 10.3.0 (Rev2, Built by MSYS2 project) configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-libxml2 --enable-gmp --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libdav1d --enable-libzvbi --enable-librav1e --enable-libsvtav1 --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxvid --enable-libaom --enable-libopenjpeg --enable-libvpx --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-ffnvcodec --enable-nvdec --enable-nvenc --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-libglslang --enable-vulkan --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libilbc --enable-libgsm --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint libavutil 57. 0.100 / 57. 0.100 libavcodec 59. 1.101 / 59. 1.101 libavformat 59. 3.100 / 59. 3.100 libavdevice 59. 0.100 / 59. 0.100 libavfilter 8. 0.102 / 8. 0.102 libswscale 6. 0.100 / 6. 0.100 libswresample 4. 0.100 / 4. 0.100 libpostproc 56. 0.100 / 56. 0.100 [matroska,webm @ 000001d82c17b400] Could not find codec parameters for stream 5 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options [matroska,webm @ 000001d82c17b400] Could not find codec parameters for stream 6 (Subtitle: hdmv_pgs_subtitle (pgssub)): unspecified size Consider increasing the value for the 'analyzeduration' (0) and 'probesize' (5000000) options Input #0, matroska,webm, from 'Originale_ridotto.mkv': Metadata: ENCODER : Lavf59.3.100 Duration: 00:03:20.20, start: 0.000000, bitrate: 26275 kb/s Chapters: Chapter #0:0: start 0.000000, end 200.000000 Metadata: title : Capitolo 01 Stream #0:0(eng): Video: h264 (High), yuv420p(progressive), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn (default) Metadata: BPS-eng : 17908166 DURATION-eng : 01:31:03.624833333 NUMBER_OF_FRAMES-eng: 130996 NUMBER_OF_BYTES-eng: 12230436033 SOURCE_ID-eng : 001011 _STATISTICS_WRITING_APP-eng: MakeMKV v1.14.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2019-08-20 08:27:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID DURATION : 00:03:20.199000000 Stream #0:1(ita): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s (default) Metadata: title : Stereo BPS-eng : 192000 DURATION-eng : 01:31:37.216000000 NUMBER_OF_FRAMES-eng: 171788 NUMBER_OF_BYTES-eng: 131933184 SOURCE_ID-eng : 001105 _STATISTICS_WRITING_APP-eng: MakeMKV v1.14.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2019-08-20 08:27:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID DURATION : 00:03:20.000000000 Stream #0:2(eng): Audio: dts (DTS-HD MA), 48000 Hz, 7.1, s32p (24 bit) Metadata: title : Surround 7.1 BPS-eng : 4955718 DURATION-eng : 01:31:02.754163888 NUMBER_OF_FRAMES-eng: 512059 NUMBER_OF_BYTES-eng: 3383983564 SOURCE_ID-eng : 001100 _STATISTICS_WRITING_APP-eng: MakeMKV v1.14.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2019-08-20 08:27:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID DURATION : 00:03:20.009000000 Stream #0:3(eng): Audio: dts (DTS), 48000 Hz, 5.1(side), fltp, 1536 kb/s Metadata: title : Surround 5.1 BPS-eng : 1508781 DURATION-eng : 01:31:02.754163888 NUMBER_OF_FRAMES-eng: 512059 NUMBER_OF_BYTES-eng: 1030262708 SOURCE_ID-eng : 001100 _STATISTICS_WRITING_APP-eng: MakeMKV v1.14.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2019-08-20 08:27:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID DURATION : 00:03:20.009000000 Stream #0:4(eng): Audio: ac3, 48000 Hz, stereo, fltp, 192 kb/s Metadata: title : Stereo BPS-eng : 191992 DURATION-eng : 01:30:59.784041666 NUMBER_OF_FRAMES-eng: 170612 NUMBER_OF_BYTES-eng: 131030016 SOURCE_ID-eng : 001101 _STATISTICS_WRITING_APP-eng: MakeMKV v1.14.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2019-08-20 08:27:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID DURATION : 00:03:20.000000000 Stream #0:5(ita): Subtitle: hdmv_pgs_subtitle (default) Metadata: BPS-eng : 38797 DURATION-eng : 01:30:04.044479166 NUMBER_OF_FRAMES-eng: 2306 NUMBER_OF_BYTES-eng: 26207661 SOURCE_ID-eng : 001205 _STATISTICS_WRITING_APP-eng: MakeMKV v1.14.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2019-08-20 08:27:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID DURATION : 00:03:16.050000000 Stream #0:6(eng): Subtitle: hdmv_pgs_subtitle Metadata: BPS-eng : 38959 DURATION-eng : 01:30:04.044479166 NUMBER_OF_FRAMES-eng: 2498 NUMBER_OF_BYTES-eng: 26317196 SOURCE_ID-eng : 001200 _STATISTICS_WRITING_APP-eng: MakeMKV v1.14.4 win(x64-release) _STATISTICS_WRITING_DATE_UTC-eng: 2019-08-20 08:27:57 _STATISTICS_TAGS-eng: BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES SOURCE_ID DURATION : 00:03:18.261000000 At least one output file must be specified -
No.If you have subtitles. at least one has to be default.
BEFORE The Swedish subtitle is default.
AFTER Runing the codeCode:Unique ID : 223285109232700144922718589550430786960 (0xA7FB25D6445299E083147A7F60E41590) Complete name : D:\00\Video.mkv Format : Matroska Format version : Version 4 File size : 1.17 GiB Duration : 44 min 0 s Overall bit rate mode : Variable Overall bit rate : 3 821 kb/s Encoded date : UTC 2018-03-31 19:58:40 Writing application : mkvmerge v14.0.0 ('Flow') 64bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings : CustomMatrix / BVOP Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=12 Format settings, picture structure : Frame Codec ID : V_MPEG2 Codec ID/Info : MPEG 1 or 2 Video Duration : 44 min 0 s Bit rate mode : Variable Bit rate : 3 042 kb/s Maximum bit rate : 9 608 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.293 Time code of first frame : 00:00:00:00 Time code source : Group of pictures header GOP, Open/Closed : Closed Stream size : 957 MiB (80%) Default : Yes Forced : No Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 44 min 0 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 60.4 MiB (5%) Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 44 min 0 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 60.4 MiB (5%) Service kind : Complete Main Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 44 min 0 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 60.4 MiB (5%) Service kind : Complete Main Default : No Forced : No Audio #4 ID : 5 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 44 min 0 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 60.4 MiB (5%) Service kind : Complete Main Default : No Forced : No Text #1 ID : 6 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 42 min 33 s Bit rate : 2 234 b/s Count of elements : 280 Stream size : 697 KiB (0%) Language : Swedish Default : Yes Forced : No Text #2 ID : 7 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 42 min 33 s Bit rate : 2 905 b/s Count of elements : 385 Stream size : 906 KiB (0%) Language : English Default : No Forced : No Text #3 ID : 8 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 42 min 40 s Bit rate : 2 650 b/s Count of elements : 370 Stream size : 828 KiB (0%) Language : French Default : No Forced : No Text #4 ID : 9 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 42 min 40 s Bit rate : 2 720 b/s Count of elements : 387 Stream size : 850 KiB (0%) Language : French Default : No Forced : No
There is no default subtitles.Code:mkvmerge -o NoDefault.mkv --default-track 5:no Video.mkv
Code:General Unique ID : 174987444822762365610316376077894787735 (0x83A55B2200CDB471951A97284AC1A297) Complete name : D:\00\NoDefault.mkv Format : Matroska Format version : Version 4 File size : 1.17 GiB Duration : 44 min 0 s Overall bit rate mode : Variable Overall bit rate : 3 815 kb/s Encoded date : UTC 2021-06-24 14:41:52 Writing application : mkvmerge v8.2.0 ('World of Adventure') 64bit Writing library : libebml v1.3.1 + libmatroska v1.4.2 Video ID : 1 Format : MPEG Video Format version : Version 2 Format profile : Main@Main Format settings : CustomMatrix / BVOP Format settings, BVOP : Yes Format settings, Matrix : Custom Format settings, GOP : M=3, N=12 Format settings, picture structure : Frame Codec ID : V_MPEG2 Codec ID/Info : MPEG 1 or 2 Video Duration : 44 min 0 s Bit rate mode : Variable Bit rate : 3 036 kb/s Maximum bit rate : 9 608 kb/s Width : 720 pixels Height : 576 pixels Display aspect ratio : 4:3 Frame rate mode : Constant Frame rate : 25.000 FPS Standard : PAL Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Compression mode : Lossy Bits/(Pixel*Frame) : 0.293 Time code of first frame : 00:00:00:00 Time code source : Group of pictures header GOP, Open/Closed : Closed Stream size : 955 MiB (80%) Default : Yes Forced : No Audio #1 ID : 2 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 44 min 0 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 60.4 MiB (5%) Service kind : Complete Main Default : Yes Forced : No Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 44 min 0 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 60.4 MiB (5%) Service kind : Complete Main Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 44 min 0 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 60.4 MiB (5%) Service kind : Complete Main Default : No Forced : No Audio #4 ID : 5 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 44 min 0 s Bit rate mode : Constant Bit rate : 192 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 60.4 MiB (5%) Service kind : Complete Main Default : No Forced : No Text #1 ID : 6 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 42 min 33 s Bit rate : 1 333 b/s Count of elements : 280 Stream size : 416 KiB (0%) Language : Swedish Default : No Forced : No Text #2 ID : 7 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 42 min 33 s Bit rate : 1 726 b/s Count of elements : 385 Stream size : 538 KiB (0%) Language : English Default : No Forced : No Text #3 ID : 8 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 42 min 40 s Bit rate : 1 623 b/s Count of elements : 370 Stream size : 508 KiB (0%) Language : French Default : No Forced : No Text #4 ID : 9 Format : VobSub Muxing mode : zlib Codec ID : S_VOBSUB Codec ID/Info : Picture based subtitle format used on DVDs Duration : 42 min 40 s Bit rate : 1 666 b/s Count of elements : 387 Stream size : 521 KiB (0%) Language : French Default : No Forced : No -
Video=defaultCode:
ffmpeg.exe -y -i originale_ridotto.mkv -map 0 -disposition: 0 -disposition:1 forced -disposition:5 default -c copy prova.mkv
Audio1 = default+forced
Subtitle1 (ita) = default
All other streams not default, not forced
Set a default subtitle track in a .mp4 file (with BOX4)
By Alice in forum SubtitleReplies: 1Last Post: 4th Oct 2020, 16:38 -
Potplayer - Disable Subtitles?
By vanbrocklin in forum Software PlayingReplies: 2Last Post: 28th Dec 2019, 21:34 -
How can you disable MeGUI Updates?
By VideoFanatic in forum Video ConversionReplies: 3Last Post: 22nd Mar 2018, 18:12 -
Need Help Batch Remove Audio,Remove Subtitle,Change Default Audio and Sub
By Inoyama in forum Newbie / General discussionsReplies: 9Last Post: 9th Jan 2018, 15:20 -
Enable or Disable Subtitle?
By maverickluke in forum SubtitleReplies: 8Last Post: 3rd Nov 2017, 06:22
