Hi all,
I'm new to the forum and new to H.264. My degree is in electronic communication engineering (in the '80s) and my job needs me to get right up to speed with H.264.
I've been reading about sampling formats YCrCb such as sampling format 4:4:4 that codes one of the three channels as luma and the other two channels being coded as chroma using less efficient tools.
This approach is said to be such that when the input to the codec is in the 4:4:4 format with full resolution in every input component, coding two out of the three input components with less the effective chroma coding algorithm results in using more bits in those two channels. The solution is said to be to use the same algorithm, the luma algorithm, for all channels, that is, to use a common predictor.
However, what did people do before it was realised that luma should be encoded differently to chroma (due to the human vision system perceiving luma better than chroma so code luma at a higher resolution). Way back when, were the YCrCb components all coded using the same predictor or using the same technique? If so, can you point me to any technical information on that?
Many thanks, Harry
Results 1 to 1 of 1
Newbie seeking advice how to convert HEVC to x264
By vhwul62 in forum Video ConversionReplies: 12Last Post: 20th May 2021, 04:34 -
Need Newbie advice on AVI File Editing
By mrtobor in forum Newbie / General discussionsReplies: 3Last Post: 27th Jul 2019, 13:24 -
Newbie software advice - cut/combine clips with image stabilisation
By Hyrax in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2019, 18:28 -
online lesson download help me
By dogantemel1978 in forum Video Streaming DownloadingReplies: 1Last Post: 11th Nov 2016, 05:59 -
flash video download (online lesson) help me
By dogantemel1978 in forum Video Streaming DownloadingReplies: 2Last Post: 3rd Sep 2016, 13:27
