I use Aegisub's video player to get the exact frame number of a video to make cuts. On this particular video, I get the following warning:
True enough, on Aegisub's audio display, where it usually shows the location of keyframes, there are no keyframes indicated.The file is being opened using Avisynth's DirectShowSource, which has unreliable seeking. Frame numbers might not match the real number. PROCEED AT YOUR OWN RISK!
I try opening other video files in Aegisub and there are no issues. This is a quirk of this particular video file. I try to see if the issue will go away if the video is reencoded, I get the same thing on the encoded result.
So, what kind of property on a video would prompt the use of Avisynth's DirectShowSource to display it and how can I change that? I can reencode the video if I have to. I plan to cut out a piece of this video and join it to another video, both will be encoded to the same settings and I don't want this issue causing problems in the joined video as well.
I would be most grateful for any help.
Edit: Tried just cutting the video and the quirk went away and I can get accurate frame numbers now. I still would be interested in a solution that did not involve cutting. Next time, I may not have the margin to cut anything.
for the same I use VirtualDub2 directly ...Originally Posted by Compositor
https://www.videohelp.com/software/VirtualDub2責任者-MDX -
Is it drag-and-drop video and start playing it now? I remember VirtualDub1 a long time ago, I had no idea how to set it up to display a video to manipulate. Never used it again.
I use Aegisub for editing subtitles, so this is a handy secondary use.
PotPlayer exits silently after settings were opened
By Miamy in forum Software PlayingReplies: 0Last Post: 26th Mar 2021, 05:02 -
AVS scripts opened by VirtualDub but no video with AVFS
By abolibibelot in forum Video ConversionReplies: 24Last Post: 27th Nov 2018, 21:16 -
Need to change the saturation and gamma of a video with an AviSynth script
By synnchan in forum Newbie / General discussionsReplies: 9Last Post: 2nd Nov 2017, 15:06 -
Avisynth command to change aspect ratio
By pooksahib in forum Video ConversionReplies: 4Last Post: 19th Oct 2017, 09:03 -
Is it possible to change a default setting for an Avisynth plugin?
By hello_hello in forum EditingReplies: 0Last Post: 9th Aug 2016, 05:41
