Hi
I'm sorry if there's a solution in this forum to my question. I've hunted for it but have yet to find it. Here's my very specific issue, which I'm looking for advice with:
I'm extracting images from a x265 upscaled 2160p .mkv animation file, with the intention of cleaning each frame up (dust fleck removal, frame shake adjustment, and individual cel layer alteration, etc). Once cleaned, all images will then need to be reassembled in the same format as the same source video. I'll fully admit that I'm a complete newbie, but I'm driven by a sense of purpose. I want to learn. Thus far I have managed to extract the frames as .png files using VirtualDub, but it doesn't appear that VD can reverse the process as anything other than an .avi file?
My PC is a bit of a dinosaur by today's standards, so Adobe products are of no use! Other than that, anything goes!
Any and all assistance is greatly appreciated
pw
VirtualDub can read the image sequence. Just use File -> Open Video File and select the first image.
So, I followed your advice but VirtualDub just hangs (not responding). I tried it first with the entire batch of 33,600 images and figured it just needed a long time to collate everything. After 8 hours I decided to try again, with only 14 images. Same problem. The version of VD I'm working with is 1.10.4 and I have not installed any codecs other than the original software. Is there something I'm missing here?
All I want to do is mux the images into an .mpeg4 video file (the original source I extracted the images from in VD was an .mkv). Thanks for your help. -
Cover.png for MKV files gone black in Explorer.
By Tombless in forum Newbie / General discussionsReplies: 17Last Post: 9th Mar 2020, 06:16 -
Converting TTML2+PNG Subtitles to BDN(XML+PNG)
By MounaLafi in forum SubtitleReplies: 6Last Post: 25th Jan 2019, 07:48 -
Are there any programmer,who can create vfw/directshow based X265 encoder?
By Stears555 in forum Video ConversionReplies: 77Last Post: 30th Jun 2018, 03:30 -
How to create a video from recorded audio and a PowerPoint (or images)
By kelemvor in forum EditingReplies: 1Last Post: 24th Sep 2017, 23:03 -
Converters won't convert MKV x265 encoded video
By NCC1966 in forum Video ConversionReplies: 3Last Post: 21st Dec 2016, 13:41
