I have a video I'm trying to convert. It's 1920x1080, but the initial segment in the video is full frame, then 2 minutes in, goes to widescreen and then has other full frame parts interspersed throughout.
The issue I'm having is that handbrake will re-encode and set everything to full frame instead of just the various segments. I tried setting Anamorphic to none to ensure that "video storage and display dimensions will be identical" but it isn't.
Anyone know the proper settings?
What would be needed for this is:
a. source would have to be completely analyzed regarding black bars and PAR
b. source would need to be split in parts where the black bars and PAR is the same
c. each of the parts would need to be cropped and encoded separately
d. encoded video parts would need do be joined into a container which supports changing resolution (assuming the PAR is always the same)
I don't know of any automated solution for this + most media players will not support this.
(Years ago I did create such content and created a .ts file with different resolutions that could be streamed, so I know it's possible, but I doubt there is an automated solution.)
-> Can't be done with Handbrake, MeGui, StaxRip, Hybrid, VidCoder or any normal encoding gui atm.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
okay, I clearly misunderstood what the target was. *gig*
Help Needed with Handbrake Picture Judder
By MoonlightsMuse in forum Video ConversionReplies: 22Last Post: 20th Feb 2021, 03:36 -
Video loses contrast after encoding to any format with HandBrake
By vitexikora in forum Video ConversionReplies: 12Last Post: 19th Dec 2019, 18:07 -
Quality difference between DV and S-Video outputs
By mkd8919 in forum Capturing and VCRReplies: 6Last Post: 18th Apr 2018, 07:32 -
PCM to which format in handbrake?
By RandmTask in forum Video ConversionReplies: 3Last Post: 30th Jun 2017, 20:16 -
Audio lost in Handbrake during conversion from .webm to .mp4 format
By Cruisecontrol in forum Video ConversionReplies: 13Last Post: 19th Sep 2016, 17:15
