Hi everyone,
I am going out of my mind trying to trim extremely long 4K MOV files that were shot on the Lumix S5. Some files are up to 30 minutes long with only a minute or two of content that needs keeping. In terms of media management, I need to trim the clips without loss or re-encoding.
Lossless Cut seemed too good to be true, and the resulting clips seem to be the correct size in terms of data - for example if I cut half of a 20GB file the resulting file is the expected 10GB. BUT the new clip won't import into Premiere Pro. Only audio comes in. Furthermore, if I try to play it in VLC it is also audio only, with the warning 'VLC could not decode the format "aivx" (No description for this codec)'.
I can't get my head around why there is a codec issue if there is no re-encoding and the original file plays fine in both Prem and VLC. I also tried Shutter Encoder and the result is exactly the same. Despite digging for information it doesn't seem to be a reported issue by anybody else. I see tutorial videos of people splitting their files and playing them back no problem, so is this something specific to the format of Lumix S5 files?
Any advice greatly appreciated!
Simon
Question about Lossless Cut Editor
By FL-Artist in forum EditingReplies: 3Last Post: 6th May 2021, 15:19 -
Lossless cutting of mov files
By Alonshow in forum EditingReplies: 2Last Post: 13th Feb 2020, 17:25 -
Lossless Cut Problem
By FL-Artist in forum EditingReplies: 8Last Post: 25th Dec 2019, 21:45 -
Problem with Lossless Cut
By FL-Artist in forum EditingReplies: 1Last Post: 3rd Feb 2019, 10:40 -
Mov-Files- from camera-not working anymore in Windows Mediaplayer 11-WINXP
By 3dreal in forum Software PlayingReplies: 1Last Post: 26th Nov 2016, 10:34
