Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 77
  1. Saw this pop up and thought it was pretty interesting.
    Any of the hardware folks have any opinion on the list of modifications here? Would be awesome if some people started refurbing these. Although this price point seems insane to me.
    https://www.ebay.com/itm/274833902321
    Datavideo TBC-1000 Single Channel Full Frame 4:2:2 Time Base Corrector
    Refurbished with Low-Noise Modifications
    Full documentation available as PDF on request
    Items Included
    Modified TBC-1000 device
    12V 1.5A power supply with ferrite bead
    2x Male BNC to female RCA adapters for composite video
    2x Male S-Video to female BNC adapters for S(Y/C) video
    4x Male/Male BNC patch cables
    2x BNC 75Ω terminators
    Modifications Made in TBC-1000 ModV1RevB
    The goal of the modifications we’ve made is to provide the high-quality, low-noise signal characteristic of the TBC-100 device, while maintaining the convenience of being a standalone device. The result is a device that is perfectly suited for incorporation into a modern analog video digitization workflow: the most common use case of the TBC-1000 device today. Modifications from the original device are as follows:
    Distribution amplifier board removed entirely.
    Power supply uses a linear voltage regulator—the same regulator used in the TBC-100 product.
    All electrolytic capacitors replaced with new Nichicon brand capacitors.
    BNC connectors are used for all inputs and outputs—for both composite and S-Video signals.
    New internal coax wire from connectors soldered directly to PCB, providing the cleanest possible signal path to the board.
    Input selector toggle switch added, allowing for input to be selected regardless of which cables are connected to the device.
    All inputs and outputs moved to the back of the unit.
    The status LED on the TBC-100 board (previously hidden from view inside of the case) is exposed as a blue LED on the front panel of the device, providing more insight into the operation of the device.
    Operation
    Install equipment as shown in the installation diagrams. Add BNC terminators to unused output connectors.
    Set the input selector switch to the desired input signal (composite vs. S-Video).
    Turn the power switch on. Red power LED will illuminate and blue status LED will flash in regular 3-second intervals.
    Signal will be output to both composite and S-Video outputs regardless of which input is used.
    Unit is capable of running continuously for many hours. However, it is recommended to power off the unit using the power switch in the back when not in use to extend its lifetime.
    Jan 2016
    Good luck to him, He is asking almost $4k for it, People think okay I got money in the bank I buy it use it then sell it, Chances of selling it at the same price is slim to none not to mentien the losses involved which can amount to up to $500 between shipping, insurance, ebay fees and Paypal fees.
    I like the S-Video to BNC mod though.
  3. The price is utterly outrageous, but this is where we are now. Anything slightly old related to audio, video or photography with a definite "cult" behind it has skyrocketed, along with service fees to repair them. The eBay price floor for "pig in a poke" random untested DataVideos sold by indifferent non-tech sellers is north of $1500, so $3K for a well-renovated customized TBC-1000 is in line with that. Basically if you did not buy one of these ten years ago when they littered eBay for $400-$500 LNIB, you're screwed today if you suddenly need one.
    I've been in touch with someone who had this eBay tech retrofit these mods (except for the SVideo>BNC conversion) on his own existing TBC-1000. The work was done very very cleanly: the mods look better than DataVideo's original construction, so he clearly has experience doing careful work on delicate electronics. Functionally the unit performs well, with none of the annoying quirks of the original unmodified design. While the price is absurd, if you want/need a really solid TBC-1000 and can afford the cost this person might be a good resource. Personally, I'm interested but can't afford it right now: luckily my stock TBC-1000 is in good working order aside from the typical glitchy internal wiring harness.
  4. Yeah the price is definitely ridiculous. These TBC1000s are pretty often going for over $1k these days, so I could see up to 2 grand for a refurbished and modified one like this. But double that price is just another level.
    Would be awesome to replicate this though at a price point that is a little more reasonable.
    "Refurbished with Low-Noise Modifications" is potentially nonsense.
    There's only 2 things that can be done.
    - replace bad caps, which MAY or MAY NOT fix cap-induced noise
    - bypass the VP299, which again MAY or MAY NOT remove jailbar noise when present
    I've been rebuilding TBC-1000s for years. It's neither easy nor fun. My rebuilts have been in the $2k range.
    That price is ridiculous.
    Replacing s-video with BNC is dumb as hell. The BNC adapters are an added potential quality reducer, and most BNC cables suck compared to s-video (including dirt-cheap s-video cables).
    Coax? WTF?
    The TBC-100 "status LED" does nothing that makes any sense, not documented at all. Knowing DataVideo, there's a good chance it was an abandoned LED that did nothing more than randomly flash due to having no instructions in the chipsets.
    It comes across as a pointless hobby project ("gee, I wonder if I could do ___ to it?") trying to be sold for 2x+ fair market value for any TBC. For $4k, get a 3rd-gen TBC-3000 (will take time to locate), which crushes TBC-1000 quality in all regards.
  6. Originally Posted by nicholasserra View Post
    Well, thats the great big joke when it comes to this sort of thing. The actual replacement parts cost just a few dollars, labor to install them perhaps a few hours. If you have excellent skill at soldering and replacing modern electronics components, theoretically this could be replicated DIY for next to nothing. But therein lies the rub: few of us have the skill or nerve required to mess with a little box thats worth $1500 in as-is condition.
    Its the same with other desirable items needed for transfer work, like restoring the fabled and infamous Panasonic AG-1980 VCR. Currently, the few dedicated techs specializing in that work are charging $700 or more to fully service a customer's own AG-1980, while one tech who also sells turnkey restored 1980s is asking $1500 and up for them.
    The cost today is far beyond what most of us were used to paying for functional examples of such items 10-15 years ago, but times change and supply of working as-is units dries up. Today many of these legendary devices need a complete overhaul by a tech who truly knows what they're doing. That specialized skill and knowledge comes at a price, but if you watched over their shoulder and saw the time/effort involved you'd understand the cost. You still wouldn't like it, but you'd understand it.
    eBay's shady business model changed yet again this past year, to the point they are now actively hostile and quite abusive to sellers. So asking prices for specialty items like this modded TBC-1000 on eBay do not necessarily reflect the world outside the hothouse trainwreck that is eBay. Sellers are padding prices by a huge percentage just to make up for how eBay is screwing them over, plus to discourage the sort of typical a-hole game-playing buyer that now makes every eBay sale fraught with risk. If there was a reasonably accessible alternative to eBay selling, I'm pretty sure that $2995 starting price would be hundreds less.
    For perspective, check what technicians are charging to restore a vintage Thorens belt drive turntable or overhaul a Rolleiflex TLR. Its altogether beyond the pale, and out of reach now for any average Joe without deep pockets. There was a great pricing divide around 2010: if you got into these interests before then, purchase price plus overhaul verged on reasonable. After 2010, everything doubled, tripled, quadrupled as demand went up and supply of items and skilled techs dwindled.
    The divide was between 2010-2015. There was a lull, less DIY, more gear available. That same gear is either now broken, or in the hands of hobbyists and pros that are not letting go. Almost no supply, high demand. That's unlikely to change. The support levels for these best TBCs is now well within the $1k-2k range, don't expect a drop. Most items these days comes from estate sales, storage units, etc -- not owners that knew how these work (or were supposed to work). So you too often pay a high price to somebody that doesn't know if it even works, when using eBay.
    Many of us actually pre-date the 2000s for video. I remember when TBCs were $500-$1k new, then AVT-8710 a bit less (far less during black junk days), then back up to $500-$1k, then inflation in past 4-5 years slowly drove those into current valuations. Inflation has hit everything from food to hobbies. Back in 2014, a retail 6" action figure was about $15. Now it's $25+. That won't be going down. The after-market for figures is easily 2x+ in most cases, if you don't grab it in stores during the short window of availability.
    I routinely see people pay $$$$ for singular car parts and $$$ for a single action figure. The car parts are a mix of stupid (pricey spinny things) and functional (true parts), and the action figures are just pretty stuff for your shelf. A TBC is an advanced tool, sharing more with a riding lawnmower than a Netflix subscription (ie, "video"). That Netflix sub is $ peanuts, while the mower is $$$$. You cannot conflate all video in terms of budget and valuation. A VCR at Walmart in the 2000s is NOT the basis upon which to value TBCs. To be blunt, it's just being clueless about economic reality. Somebody else will buy it (unless the price is just unreasonable, as is the case here), having seen the value, while you dawdle and whine. Odds are, the longer you wait, the more it'll cost later. TBCs are an unavoidable necessity for quality video capture -- or the ability to capture at all. It's a tool required for the task that we've elected to do ourselves, rather than pay others (who may or may not be using TBC, far too many bad services out there, which is likely why you want to DIY).
    I don't see that eBay is some horrible place for sellers, but in fact worse for the buyers. The "buyer protection" can literally drag on for 2-3 months, while you're out both money and item. There are known video gear scammers, namely that butthole in Houston, that will fight you, and it will drag out. He's further figure out a way to game the system to remove negative feedback, and has multiple usernames. So sellers don't necessarily get the raw deal, sometimes sellers ARE the raw deal. I paid $700 for a "new" (BS!) SSD earlier this year, and it took 2 months to resolve. No refund, no SSD, and I was pissed, for 2 months.
    TBCs and pricing require a different mindset. You can't simply declare something "expensive" without knowing what goes into it, what it does. It's not a toaster.
    Jan 2016
    I guess the professional gear that uses BNC connectors and cables for decades without a hitch is dumb, I wouldn't call S-Video dumb but it's the flimsiest design I ever used. BNC connection is firm due to the locking mechanism, low noise, can run longer. I had to reflow my S-Video socket on one of my VCR's twice, The third time it will be a BNC upgrade.
    Professional gear was intended for BNC connections, without adapters.
    The TBC-1000 is intended for use with (at very least) s-video input from quality decks, meaning adapter needed.
    Passing the TBC out to BNC is unusual, somewhat mixing gear. I know you like SDI workflows, and that's where you're coming from. But in general, it's far more complicated, and limiting in several ways. Serious users generally don't want to touch it, and casual users definitely don't want to. I guess if you insist on BNC-using workflow, this is what you're been waiting for. Go for it, $4k, that's all you.
    s-video isn't flimsy, and BNC isn't firm. Each has slop in connections and cables. What I can say is that a cheap BNC is bad news, while a cheap s-video is almost always fine. The separated wires don't induce noise the same as other connections. Shielding is less important on s-video that others. It's one of the few times that you can go cheap with video, and still be perfectly fine. (Note: Not all cheap cables. But many are fine.)
    Running longer is mostly about gauge and shielding.
    I've had two s-video connectors go bad in 30 years. I rarely see or hear about that. The main issue is constant plug-unplug-replug that kills those.
  10. Capturing Memories dellsam34's Avatar
    Jan 2016
    You don't need adapters (see picture below), One cable with one side BNC the other side S-Video, Yes dual BNC can look ugly, S-Video is sexy, But I've had captures with chroma flicker that I traced back to a faulty S-Video socket with good soldier joints, Unfortunatly those sockets on the back of the VCR are proprietary and finding the exact replacement part is impossible, The only way to keep the original socket is to keep changing S-Video cables and hope for the best. Never had that happen with BNC equiped decks or cables and I do have cheap BNC cables. At the end of the day mods like these are personal customisations for better performance, it never meant to keep the stock look. One may like the orginal Mustang, another likes the performance add on.
  11. Video Restorer lordsmurf's Avatar
    I've never seen BNC>YC cables that weren't crappy, even the expensive ones from Extron. The one shown above has essentially no shielding, and is completely flimsy. I've had a difficult time finding good BNC<>s-video in the past, and it always irritates me. Yet ironically, BNC<>composite was far easier, simply using a good BNC<>composite adapter (not cheap, not gold, but good). In fact, those exact BNC/composite devices had a fairly robust composite, not blurry like many devices (thus proving bad composite is due to bad connections/devices, not entirely the fault of composite itself).
  12. I am so glad I finished my vhs projected 9 years ago !, I had good luck with this little thing..........https://www.bhphotovideo.com/c/product/276891-REG/AV_Toolbox_AVT_8710_AVT_8710_Multi_S...Time_Base.html
    PAL/NTSC problem solver.
    USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
  13. Video Restorer lordsmurf's Avatar
    The black AVT-8710 had flawed chipset that actually induced the very timing errors it was suppose to remove. Frame sticking, dropped frames, frame ghosting, etc.
    Well documented: http://www.digitalFAQ.com/forum/vcr-repair/3053-avt-8710-doa.html
  14. Originally Posted by lordsmurf View Post
    It has been increasingly seller-hostile for the past six years, culminating in their official policy that there is really no such thing as "brand new sealed, no returns once opened" or "as-is, this item is broken, I'm clearly telling and showing you it was run over by a truck, no returns" categories. Every item for sale on eBay is returnable for any reason whatsoever, including shipping both ways, and within a SIX MONTH window after purchase. So while yes, there are always some incredibly clever scam sellers who find ways to take the money and run, in the broader sense eBay allows buyers to run wild and take total advantage of sellers while stripping sellers of any rights at all. There is ZERO protection now for sellers on eBay: you are completely at the mercy of the morality of your buyer, and many buyers lose their morals when shopping eBay. Once they get a taste of being able to exploit sellers for "free test drives" (or worse "free long term rentals"), Pandora's Box cannot be closed.
    Selling high value items like JVC vcrs, DataVideo TBCs, hifi gear or good cameras on eBay was always slightly risky but is today almost untenable. Postage rates for high value insured items (or items heavier than a snow globe) are through the roof: all it takes is one selfish ass buyer to sink you financially (no refund on 3% PayPal fees, you must refund original shipping, and also pay for return shipping even for blatantly obvious buyer's remorse on new items). So someone selling a $700 item that is reasonably priced at $700 (i.e., at or below market price) risks at least a 50/50 chance that item will be bought and returned frivolously, possibly twice, at an out-of-pocket total loss of $90 to $200.There is no arguing with eBay on this point: you can march right into their offices in person and demonstrate the item was flawless, and they'll just shrug their shoulders and say "nothing we can do, buyer is always right, check your latest seller agreement fine print".
    Sellers who drag their feet, seek arbitration or refuse to comply have their assets frozen and their account seized. This is esp potent since eBay effectively killed PayPal for sellers last December and insists on direct access to seller bank accounts, with eBay holding up sales payments for as long as they want (in many cases, insisting you ship the item before they release the payment money to your bank). So yeah, a handful of real dedicated PT Barnum scam sellers do figure workarounds to defy eBay, which is how LS got stiffed on that SSD deal, but such experiences are far far less common today than sellers getting completely torched by buyers.
  15. Member ccbradley's Avatar
    Jun 2021
    Hello all,
    I am the owner of this auction, and I appreciate all of the feedback. I've lowered the starting price for the auction and enabled the feature to make offers. If you have any questions for me please feel free to contact me directly or ask in this thread. Thanks!
  16. Nice, thanks for chiming in.
    The relocation of the connectors all to the back and the new caps alone make this pretty desirable at this price point at least. Always wanted to rack mount my TBC1000, obviously inputs on the front cause issues with that.
  17. Capturing Memories dellsam34's Avatar
    Jan 2016
    Originally Posted by ccbradley View Post
    Hello all,
    The price was high but I have to admit that you did a pretty nice BNC mod, I would suggest that you provide the buyer with high quality BNC/S-Video cables instead of BNC-BNC female and BNC male-S-Video extension. I'm planning on doing the same to my VCR's since my capture gear all Y/C BNC.
  18. Member ccbradley's Avatar
    Jun 2021
    Hello all,
    Thanks for the suggestion. I had considered it, but I figured that most serious users would have their own opinions about which cables are best. The cables included are just for the convenience of being able to see the device is operational as soon as it arrives.
  19. Member ccbradley's Avatar
    Jun 2021
    If you already have a TBC-1000 I’d be happy to make modifications to it for you. Feel free to PM me if interested.
  20. Member ccbradley's Avatar
    Jun 2021
    Figured I would share the documentation that I mention in the auction listing… see attached.
    Image Attached Thumbnails TBC-1000_ModV1RevB_60c8585a15ba6.pdf
  21. Capturing Memories dellsam34's Avatar
    Jan 2016
    Well documented modification and great information, Like any consumer device TBC-1000 is built with money saving in mind using readily available cheap components, But you did bring it up to standards used by proffesional gear, Kudos. I would love to make you an offer but I just don't need it, Hopefully it finds a better home.
  22. Video Restorer lordsmurf's Avatar
    That's definitely better. But you still have the power switch buried on the back. The TBC-1000 doesn't have rack mounts, never intended for that, but something should be rig-able.
    If you can locate quality cables for that, in the now 2020s, great. I had a difficult time locating truly good BNC>s-video back in 2019, either cable or adapter. Everything these days is flimsy, many of them fell part with light use. Even the Extron cables sucked, and added noise the signal. I'm not looking for ridiculously over-thick Monster cables, either. Just good cables, good gauge, adequate shielding, won't come apart at the heads after a few mere plug/unplugs. I didn't get the Aja, looked to be nothing more than rebadged Chinese cables, the same as everything else I saw. Unless you're going BNC VCR > TBC > BNC capture, I think BNC is a mistake here.
    The irony here is that cheap free s-video cables are often fine. The s-video cables that came with my JVC VCRs are some of the best cables that I still use. Most others are disposable, and I toss at least 1 pair in the trash every year (or recycle when I can). So I consider BNC a downgrade.
    Hello all,
    Thanks!
    Hello.
    Question: What do you think the value of the VP-301x LED is? Because as far as I know (and I inquired with DataVideo on this), the LED is just random flashing. It's one of those things on the TBC-100 that had intentions, but didn't go anywhere. There's a number of aspects of the TBC-100 (and TBC-1000) that were scrapped before release, and just never changed.
    The re-cap is nice, but it only addresses the output block. The input of the TBC-1000 is far more problematic.
    If you ever want to discuss the TBC-1000 more in-depth, fell free to contact me. I'm all for upgrading these (remove VP-299, etc, just not BNC), and refurb'ing when needed (re-cap, etc). As you surely realize, it takes time and funds to put a TBC-1000 back into shape.
  23. Member
    Nov 2006
    I am the one Orsetto mentioned was in contact with who has the modified TBC-1000. Yes mine doesn't have Y/C bnc's but I contacted Blue Jean Cable and ordered a s-video [male] to two bnc [male]. It's made by Belden and seems pretty nice quality.
    Overall I'm very happy with Bradley's work on my modified TBC-1000. He emailed pictures, documentation, constant contact with the progress, printout of all documentation. I'd like to believe it's as good or better than the TBC-100.
    I had been closely monitoring eBay, even had Datavideo TBC-1000 saved in a search so I'd get a notification when one got listed. After a few weeks of no notifications I checked the completed listings/sold items and saw about four that all sold the second they got listed. Then one got listed (by Bradley) so I contacted him to see if he could either re-cap and/or bypass the distribution board. Who needs four outputs when capturing? With a few suggestions from Orsetto, which I relayed to Bradley they were incorporated in his mods for the better. All the TBC-1000's that recently were listed sold for $1400+. Then someone had a rack of gear with a TBC-1000 with the auction, and later listed the TBC-1000 separately and that stock unit sold for $1850.
  24. Member
    Mar 2021
    Boston
    Hey you guys have been watching this too.
    It's mentioned that during this modification the power supply was changed to a linear voltage regulator. You said the switch-mode regulator adds noise to the system via ripple voltage.
    One of the upsides of the TBC 100 is that it's connected to a computer's PSU. It's been said that TBC 1000s are sensitive to a dirty grid which next to aging caps can add to most of the noise which the TBC100 avoids. I wonder if this mod addresses that.
    Overall looks like stellar and quality work. I hope it makes it to a good home whoever ends up buying it.
  25. Member ccbradley's Avatar
    Jun 2021
    I like this idea; the power switch could definitely be moved to the front for a rack-mounted situation.
    This workflow is actually the use case that I had in mind when making these modifications. Things definitely get messy when you have to convert to S-video connectors.
    I agree that framed this way, BNC could be considered a downgrade. The alternative is to use 4-pin mini-DIN connectors on the device, most of which are not manufactured for use with video signals these days, from what I’ve seen. My opinion is that BNC is the most future-proof option and when used with the right equipment, introduces the least amount of noise.
    It does seem to be programmed to just flash at regular 3 second intervals at all times during operation. The value in being able to see that is that you know when the MCU is not working for some reason. I encountered a situation in the past where the 7808 on the VP-299 was going bad (on an older model back when the VP-299’s 8 volts were provided directly to the VP-301x) and was not able to supply the necessary current. This caused a very noticeable sporadic flashing of the LED—something that I was lucky to be able to see since the case was open at the time. It’s not a huge value-add item, but it does potentially provide an early warning that the device needs repair. Plus it looks cool.
  26. Member ccbradley's Avatar
    Jun 2021
    Yes, the switch mode regulator on the "power board" that Datavideo designed is a great source of noise. A switch mode regulator with low noise output requires quite a bit of careful engineering. Datavideo's design is comprised of 7 discrete components.
    Linear regulators (as long as they are properly cooled) add very little noise to the incoming voltage. This mod uses a Texas Instruments LM7805 linear regulator thermally-mounted to the metal case of the box, away from the main board itself. I think this is pretty close to ideal and gives the user the most options. An interesting and very inexpensive idea might be to power the device from a 3S lithium battery connected to the DC jack instead of a power supply. This would probably give you less noise than even a computer's PSU. Just make sure the battery has built-in over-discharge protection and does not do any sort of voltage regulation. An example of a suitable battery and protection board:
    https://www.amazon.com/Zeee-Helicopter-Airplane-Quadcopter-Multicopter/dp/B07CWS1HC5/r...4508250&sr=8-7
    https://www.amazon.com/AITRIP-Charger-Protection-Lithium-Battery/dp/B08JYTG82N/ref=sr_...508250&sr=8-10
    With this battery you could probably run the device for about 6-8 hours on a full charge.
  27. Member
    Mar 2021
    Boston
    Thanks for the great explanation. Yeah part of the Datavideo's downfall was that it didn't handle "dirty power" all that well and could soften the image compared with other TBCs out there e.g. large city power grids, lots of traffic. Upgrading the regulator to the same one found in the TBC 100 which are favored in low noise applications is a big plus. That should in theory improve noise. That to me is potentially one of the large benefits I'm seeing here.
    I know many on here already know this, but for any non members browsing. A voltage regulator works by detecting any changes in the power supply and then adjusting it according to the load. It converts dirty power into a clean one without any disruptions. Some regulators introduce more noise than others. The TBC 1000s can be notoriously noisy or not depending on your location.
    Your documents provide a great explanation outlying the differences between the 100 and 1000 model design in better terms than I have ever read in other forums before. They most definitely are not the same. Very useful information for future modders themselves.
    Within the next two weeks I am loading off and selling a bunch of my unused equipment and will be in the market for a "new" TBC. However I really need proc controls in my setup and it would be nice not to have to locate and use a separate Sima SCC. Depending on what I can find out there I may end up gravitating towards the TBC 1000 if I don't find another option.
    Nice to see you again! Longtime forum member right here from the Great White North. I've chosen Y2021 to start building my VHS studio project. What better thing to do during the lockdown. Have a little cheap fun right? I've been procrastinating for the last decade. Is now a good time to jump into the pool? Is the water warm? Does the beer taste good? I'm ready to crawl back into my shell.
  28. Have a question for you ccbradley, what's your testing process on these? I ask anyone who seems to know about fixing them, as I want to make sure my gear is still operating correctly. Do you have a specific way of verifying it's working correctly and the noise is acceptable?
  29. Member ccbradley's Avatar
    Jun 2021
    My testing setup includes Tektronics TSG-100 test signal generator, 1710J waveform monitor and 1720 vectorscope. I first test visually with a macrovision VHS tape to verify that the TBC is correcting the timing. After that I follow the general principles laid out in this document to characterize the signal noise and verify that there aren’t any obvious outliers: https://download.tek.com/document/25W_7247_1_rfs.pdf
    The process is relatively quick to determine pass/fail when comparing the output signals from a known-good TBC-1000 and a TBC-1000 under test.
  30. Originally Posted by BenKlesc View Post
    You're looking for a unicorn, I'm afraid: age has not been kind to many of the commonly available TBCs with built-in proc amp controls.
    As I'm sure you already know by now, 90% of the used "pro" pizza-box rack mount TBCs with proc amps are either in dismal decrepit condition or unoptimized for VHS (usually both). While most newer, VHS-friendly units employed funky turn-of-the-millennium bespoke electronics that aged like goat cheese on a hot summer sidewalk between 2003 and today. TBCs with menu or button-controlled proc amps like the DataVideo TBC-3000 and the built-ins of some late JVC and Panasonic studio VCRs are often dysfunctional and unrepairable now. They worked well and earned a good rep when new, but peak performance lasted only a few years before rot set in. After digital killed off the market for pricey analog correction devices, repairs and spare parts for sophisticated modern combo gear designs dried up.
    Which is the long way of saying you'll likely have more success picking up a basic separate TBC and proc amp. For the latter, units from Sign Video seem to enjoy popular acclaim here and at DigitalFAQ.
