Hi i noticed Potplayer uses too much CPU (nearly 50%) and GPU while playing live stream 4K videos and even 1080p video but VLC only uses 1-3% CPU
both uses intel uhd 630 graphics, i have nvidia gtx1050 4gb too.
i changed potplayer to use nvidia (although intel was better to decode video) but it's still same.
What is the difference here? Does VLC really efficient to play?
I tried to disable DXVA (hardware acceleration) and changed some filter settings of Potplayer, still no difference, currently DXVA is on.
Installed Poplayer beta to check if there is a problem, still no difference (210611).
Do you have high CPU usage on Potplayer while playing 4K video too?
If i play +30mbps bitrate streams, potplayer uses even more cpu & gpu both almost 50%, vlc still uses cpu 1-5%
- VLC HEVC HDR: https://i.ibb.co/DVkrPCq/image.png
Codec: https://i.ibb.co/TwSmNZ2/image.png- Potplayer HEVC HDR: https://i.ibb.co/F702XVM/image.png
Codec: https://i.ibb.co/BqLLXtY/image.png- VLC VP9 HDR: https://i.ibb.co/4j97v9K/image.png
Codec: https://i.ibb.co/2qQ79k9/image.png- Potplayer VP9 HDR: https://i.ibb.co/YQhWywF/image.png
Codec: https://i.ibb.co/6tTrHBK/image.png
Results 1 to 1 of 1
Not able to change any advanced video playback settings in VLC or Potplayer
By Russ10 in forum Newbie / General discussionsReplies: 18Last Post: 31st Dec 2020, 07:55 -
PotPlayer x265 HEVC background problem
By tembelterazi in forum Software PlayingReplies: 7Last Post: 19th Nov 2019, 18:32 -
HEVC or H264 GPU vs CPU Another time !!!
By gringito38 in forum Video ConversionReplies: 2Last Post: 23rd Feb 2018, 05:28 -
PowerDVD has lower CPU usage in 4K@60 HEVC than potplayer&mpcHC 1080p@25AVC
By Stears555 in forum Software PlayingReplies: 18Last Post: 17th Oct 2017, 11:55 -
HEVC x265 potplayer settings
By Annonboy777 in forum Software PlayingReplies: 0Last Post: 13th Jan 2017, 06:21
