Try NordVPN to access Netflix or other streaming services from any country and also surf safe!
Results 1 to 9 of 9
  1. Hello everyone.
    For the last few months I've been trying to restore a 4th generation videotape with a very low quality transfer. Sadly, it isn't possible to get a new one so I have to work with what I have. Anyway, the biggest problem this videotape has , in my eyes, is the presence of large black halos and aberration on edges, probably caused by edge enhancements and the fact that it is 4th generation.
    I've tried several filters on VirtualDub and Avisynth to fix this (i.e. Ghost Removers, Levels, etc.) and only recently I managed to fix most if not all of it. Here's a comparison:
    https://imgur.com/a/9uW9Aox
    However, doing this generates lots of chroma bleeding that thankfully isn't as annoying to deal with as the black haloing before, but it still needs to be fixed.
    My question is, is there a better way to approach this type of haloing? if not, is there a way to fix all of the chroma bleeding left?
    Thank you all in advance for your help.
    Mar 2008
    Post a short clip of your source (15 seconds or more) that shows the problems to this thread and somebody will take a look
  3. Here's a minute and a half of the footage in question, cleaned up from noise and blocking:
    EDIT: Sample posted in comment below.
    canada
    It would be easier just to upload the video here,there's a 500mB maximum file size.
    Mar 2008
    Also post the source, if you're looks for Avisynth suggestions
  6. Here's the sample:
  7. just by the screenshots LGhost might be worth a try,..
    users currently on my ignore list: deadrats, Stears555
  8. Just viewing it, I'd guess they'd become less noticeable once you get the black levels adjusted?
    "Well, my days of not taking you seriously are certainly coming to a middle."
  9. Originally Posted by TimA-C View Post
    Thanks for your reply!
    I've got pretty results by limiting the Y levels, but it's been hard to hit a sweet spot where I can get fix the black halos without losing important details. I know those levels are the most f*cked up on this tape, but I'm absolutely sure it is fixable.
