I want a free program to remove malware from the computer.
Thanks for the advice.
Results 1 to 9 of 9
Malwarebytes detects newer malware which defender doesn't.
Defender in offline mode, then you are correct, but Defender in online, cloud powered mode stops zero day malware:
https://www.youtube.com/watch?v=qusvuBC4UrM -
Seems good,
while connecting with my android through usb w10 gives an error because of the phone running malware !
Now I need to remove it from my android, but I have no idea about it. -
Most Android device have the option to do a factory reset; there is one thing, if Win 10 is detecting the malware then it should also be able to clean it up.
Malware removal
By annie111 in forum Off topicReplies: 3Last Post: 22nd Sep 2019, 13:16 -
Is aTube Catcher now MALWARE?!?
By gastrof in forum Newbie / General discussionsReplies: 1Last Post: 7th Jun 2018, 15:00 -
FairMount Beta 1.1.0 have Malware?
By Wischmop in forum Blu-ray RippingReplies: 4Last Post: 24th Aug 2017, 04:57 -
Is this adware/malware?
By kyrcy in forum ComputerReplies: 30Last Post: 5th Aug 2016, 10:58 -
Does VSDC download malware?
By brian masson in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2016, 04:04
