  1. Hi,
    With which software can I see the weight audio contained in a kmv without extracting it?
  2. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Not sure what you mean by "weight" or "compacting" ? However guessing if you use the program MediaInfo you can inspect the contents of a MKV or most other media formats.
  3. Originally Posted by netmask56 View Post
    by weight I mean how many MB it is and with MediaInfo there isn't
  4. Extract the audio with g.e. mkvcleaver or clever FFmpeg-GUI and you have the Megabytes...
  5. Originally Posted by ProWo View Post
    as I wrote I don’t want to extract it
  6. Member Cornucopia's Avatar
    Yes there is. Don't look at the summary/basic view, look at the detailed view. It's right there, called "stream size".
  7. Just mux it again in mkvtoolnix the stream size of video and audio will be written in MediaInfo.
  8. Originally Posted by Cornucopia View Post
    Found it
    thanks a lot
