Hi,
I have tried to compare the result of h265 and h264 codec and while h265 is much better in terms of quality and size reduction, unfortunatenly in my test introduce much banding and block on dark gradient.
Here some commands that I have tried:
(h264)
This command produce a poor quality result and intruduce grain, but no bandingCode:ffmpeg -y -i title00.mkv -an -t 80 -b:v 4M ouput_h264_no_special_options.mkv
(h265)
The quality is much better but introduce banding on dark scene expecially with grey gadient. If I decrease the -cq to 22 the banding persist and seem a bit more evident.Code:ffmpeg -y -vsync 0 -i title00.mkv -an -sn -c:v:0 hevc_nvenc -rc:v:0 vbr -cq 27 -qmin 22 -qmax 40 -b:v:0 10M -maxrate:v:0 15M -gpu 0 -vf format=yuv420p10le -rc-lookahead 32 -spatial-aq 1 -aq-strength:v 15 -level:v 4.1 -t 80 -tune hq output_banding.mkv
(h265)
Very very slow with the some banding artefacts no more no less.Code:ffmpeg -y -i title00.mkv -c:v libx265 -an -aq-mode 3 -aq-strength 16 -deblock -2:-2 -g 120 -keyint_min 120 -t 80 -b:v 4M ouput_h265.mkv
My impression is that the h265 have this side effect by default.
If I reduce the gamma the banding is less visible, but the the video is more dark.
I have tried different noise redection via ffmpeg without get good result.
Someone have similar experience about this ?
There is a way to reduce/remove the banding on h265 ?
Thanks !
Use 10bit encoding. The H.265 standard has 10bit encoding in it's main profile which is why all decent hardware decoders support it.There is a way to reduce/remove the banding on h265 ?
Also:
1. without even sharing the frame size, frame rate there is no chance to judge whether 4Mbit/s might be way too low/high.
2. using 1pass bit rate encoding is usually a bad idea,... 2pass or quality based encoding usually is better.users currently on my ignore list: deadrats, Stears555, marcorocchini -
Thank you.
I have found the solution: using libx265 with this command:
the final result don't show any banding / blocking but there is a compromise:Code:ffmpeg -y -i title00.mkv -c:v libx265 -an -crf 23 -x265-params ref=4:hme=1:hme-search=umh,umh,star:subme=4:bframes=8:rd=4:rd-refine=0:qcomp=0.65:fades=1:strong-intra-smoothing=1:ctu=32:qg-size=32:sao=0:selective-sao=0:cu-lossless=0:cutree=1:tu-inter-depth=4:tu-intra-depth=4:max-merge=2:rskip=2:rskip-edge-threshold=2:rc-lookahead=80:aq-mode=1:aq-strength=1.0:rdoq-level=1:psy-rd=4.0:psy-rdoq=15.0:limit-modes=0:limit-refs=0:limit-tu=0:deblock=-4,-4:weightb=1:weightp=1:rect=1:amp=0:wpp=1:pmode=0:pme=0:b-intra=1:b-adapt=2:b-pyramid=1:tskip=1:tskip-fast=0:fast-intra=0:early-skip=0:splitrd-skip=0:min-keyint=24:keyint=240:transfer=bt709:colorprim=bt709:colormatrix=bt709:crf-min=10 -t 80 ouput_h265_forum_very_slow_crf_23.mkv
with nvidia cuda the process speed is 16x but with this command (libx265) is 0.1X.
After many tests I have undestand that the only way to get a good result is using libx265, but I still looking for a compromise with these paramaters to speedup the process.
My CPU is old Intel I5 6600T and my GPU is GTX 1060. -
Hi I tried your settings on live action video , i'm trying to get rid of banding and blocks artefacts from the converted video,
but the the speed was slow ~ 0.2x even after I down scale the video to 1024x576 Is there way to improve speed with less artefacts
weird interlacing/deinterlacing artefacts
By phelissimo_ in forum Video ConversionReplies: 11Last Post: 1st Jan 2021, 10:57 -
Removing MPEG2 compression artefacts from commercial DVDs?
By Master Tape in forum RestorationReplies: 38Last Post: 17th Aug 2020, 18:27 -
Auto-Detect Banding/Blocking?
By max_cady in forum Newbie / General discussionsReplies: 0Last Post: 3rd May 2020, 15:15 -
FFMPEG Batch Script wanted for H265 Remux
By VideoFanatic in forum Video ConversionReplies: 5Last Post: 21st Jan 2018, 11:38 -
MPC - HEVC 2160p - artefacts with NVIDIA CUVID
By asdrewq in forum Software PlayingReplies: 3Last Post: 24th Nov 2017, 12:06
