I'm ripping my Thunderbirds DVDs to MKV so that I can watch them on my NVidia Shield, and have completed all the movie disks. The one final disk is the Companion disk which is like the background info on the episodes, the explanations of each of the Thunderbirds machines, the making, original artwork, etc. I'm having issues ripping this disk.
I can play the DVD as a normal DVD in VLC, all the videos play well. However, if I try to play the VOB files individually, the video is "broken up" and unviewable and the sound cuts out every few seconds. Here's a screenshot.
[Attachment 59432 - Click to enlarge]
I tried copying the VOB files to my computer but i still get the same issue.
Anyone know what's going on?
Here is the MediaInfo on the one VOB file I am trying to play:
General
Complete name : F:\VIDEO_TS\VTS_01_1.VOB
Format : MPEG-PS
File size : 1 024 MiB
Duration : 16 min 29 s
Overall bit rate : 8 676 kb/s
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : Variable
Format settings, picture structure : Frame
Bit rate mode : Variable
Bit rate : 8 312 kb/s
Maximum bit rate : 8 500 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.802
Time code of first frame : 00:00:00:00
Time code source : Group of pictures header
GOP, Open/Closed : Closed
Stream size : 981 MiB (96%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Muxing mode : DVD-Video
Bit rate mode : Constant
Bit rate : 192 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Stream size : 22.6 MiB (2%)
Service kind : Complete Main
Menu
+-- Julian Milano
Is the DVD defective?
That seems to be a reading problem with the DVD drive.
Try the rip on another computer. -
You sure it's just not some kind of protection - the VOB's are encrypted ?
Ripping from DVD to MKV- Which audio option do I choose?
By JDMils in forum DVD RippingReplies: 4Last Post: 14th Jun 2021, 11:35 -
Ripping TV shows from a Blu-ray Disk
By tarzan54 in forum Blu-ray RippingReplies: 8Last Post: 25th Feb 2021, 19:15 -
How do I fix external hard disk that is still partially working?
By aruwin in forum ComputerReplies: 14Last Post: 24th Dec 2020, 16:57 -
MKV not working in Handbreak
By Brian7k in forum DVD RippingReplies: 0Last Post: 22nd Apr 2018, 16:13 -
Ripping episodic DVD to multitrack (audio) MKV or MP4 files
By tonyaldr in forum DVD RippingReplies: 8Last Post: 15th Jun 2017, 14:12
![Computer details: [Desktop]
Windows 7 x86 Enterprise SP1
Intel Core2 Duo, E6850 3.0 GHz
C:\ = 1TB, D:\ = 5TB
[HP-DV7]
Windows 8 x64 Enterprise SP1
Intel i7, Q740 1.73GHz
C:\ = 750GB, D:\ = 750GB Comp](/images/buttons/computer.gif)
