I have a clip that was shot with the iPhone 11 Pro,1920-1080,24fps.I can see what appears to be snow when viewed,,can anyone tell me what causes this?
Thank you,,
Results 1 to 12 of 12
The video appears to be 24 unique frames per second, with repeated frames to give a 60 fps video.
I don't think this is phone footage, this phone shoots 24 fps at 4k only
https://www.photographyblog.com/reviews/apple_iphone_11_pro_review#specifications -
Clip plays back fine here in Windows Media Player and VLC with no "snow". MediaInfo reports it as having a frame rate of 59.40 and a constant bit rate of 9.004kb/s.
The clip also plays back smoothly in DaVinci Resolve.
I would suspect the media player you are using. Here's a frame grab. As you can see, no snow.
[Attachment 59429 - Click to enlarge]Last edited by ChapmanDolly; 13th Jun 2021 at 20:14. Reason: Additional info
Canon C100 mk2 - Dell XPS8700 i7 - Win 10 - 24gb RAM - GTX 1060/6GB - DaVinci Resolve Studio 18.6.3 - Blackmagic Speed Editor - Presonus Faderport 1 - 3 calibrated screens -
Davexnet you are wrong. Look at the video recording section in that link.
This is what it says: What did I miss? ALso the bitrate is too low
Also if you search for sample movies, there is some original footage for downloadCode:4K video recording at 24 fps, 30 fps or 60 fps 1080p HD video recording at 30 fps or 60 fps 720p HD video recording at 30 fps
It also shoots at 60fps in 4k. Either this was actually shot in HD at 60fps, or it's 60fps 4k downscaled to HD which given the detail in the pic is what I suspect..
Thanks guys,,Im a bit of a novice when dealing with video,,I do notice a difference in clarity between iPhone native app and Filmic Pro. I first noticed it when editing in Premier Pro..
Thanks again,, -
It does have a significant amount of noise and (over) compression artifacts. Some noise reduction can help.
Use more bitrate. Use a better encoder. Use better encoder settings. Use variable bitrate encoding, not constant bitrate.
Drop out with alot of snow and span among many frames
By mammo1789 in forum RestorationReplies: 28Last Post: 25th Jul 2019, 18:42 -
DirectVobSub installed but not in systray and it appears to do nothing ...?
By Bansaw in forum SubtitleReplies: 4Last Post: 3rd May 2019, 13:20 -
Video appears unclean on my Tft Monitor
By Anonymous754 in forum Newbie / General discussionsReplies: 1Last Post: 22nd Feb 2019, 19:59 -
Isopropyl appears to have ruined my Hi8 camcorder
By Hypersonic1 in forum RestorationReplies: 46Last Post: 30th Jan 2019, 18:17 -
Error: Decoder appears to have frozen, corrupt audio file? SOLUTION
By TheLastOfThem in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2016, 10:50
