Hello,
It was suggested to come to this group for this problem. I recently inherited my grandfathers Canon HV20 and the many tapes of family memories with it. I have managed to get a computer set up that uses a firewire to import the video into a digital format from the camcorder. However, when I import the tapes using either iMovie or Quicktime, the audio does not seem to be imported with the video. I hear the audio through the camcorder and when I use quicktime there is indication that the audio is there but it will not show up on the finished product. Even downloading the trial version of LifeFlix did not work.
How do I save the DV Tapes to my computer with the audio intact? Is there a setting or trick that I am missing?
I can provide system specs and any other information needed to help.
Thank you for any help.
Jon
try the first solution for quicktime - https://discussions.apple.com/thread/8633781
I found an old 'guide' re using iMovie. There is a setting that intrigued me.
https://www.mpi.nl/corpus/a4guides/a4-guide-imovie.pdf -
Thank you for the guide. I am having difficulty following its directions because I think the guide is for an older version of iMovie. I cannot find some of the options that it suggests to use. Particularly with the audio export and the preferences menu in iMovie. I do not see the option to deselect "filter audio from camera" or choose PAL/NTSC for new projects.
start the tape first then the audio should come through - https://www.youtube.com/watch?v=OL3mBgChVyI
Broken video and audio when importing MiniDV from Sony DCR-TRV9E
By ArthurS in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Dec 2020, 09:39 -
Importing Hi8 tapes to MacBook w/Blackmagic Intensity Shuttle & Premiere
By TwiceUK in forum Newbie / General discussionsReplies: 4Last Post: 21st Dec 2020, 14:32 -
Problems with importing mini dv tapes
By fine0023 in forum MediaReplies: 4Last Post: 7th Jun 2020, 14:42 -
What is the proper way of importing video and audio from Blu-ray disc?
By HE1NZ in forum EditingReplies: 2Last Post: 22nd Jun 2019, 21:03 -
Artifacts in Video Playback after Importing from miniDV
By moto377 in forum Capturing and VCRReplies: 8Last Post: 15th Jan 2017, 11:55
