I JUST PURCHASED WINTV PVR USB CARD WHICH IS PAL VERSION AND MADE IN MALAYISA .
MY AIM FOR PURCHASING THIS CARD WAS TO CONVERT VHS TO HI QUALITY VCDS AND SVCDS
MY PROBLEM IS THIS CARDS CAPTURE IN VERY BAD QUALITY MPEG EVEN AT 6MB ITS VERY BLURRY I CANT COMPARE IT TO A MARKET VCD QUALITY
AFTER VISITING SOME SITE I DOWNLOADED ADVANCE TAB REGISTRY FILE . AFTER REGISTRING THAT FILE THE ADVANCE TAB IS VISIBLE BUT ITS NOT WORKING I JUST PRESS ONCE AND NOTHING HAPPEN .
THAN I DECIDED TO GO FOR ANY OTHER REALTIME MPEG CAPTURE SOFTWARE .SO FIRST I DOWNLOADED CYBERLINK POWER VCR2 BUT IT IS NOT DETECTING THIS CARD (USB) .
SO CAN U PLEASE HELP ME ABOUT FOLLOWING QUESTIONS--
CAN I USE ANY OTHER MPEG CAPTURE SOFTWARE FOR THIS CARD ??
AND WHAT IF I WANT TO CHANGE THE CODEC FOR MPEG COMPERSSION CAN I DO THAT??.
HOW TO GET WORKING ADVANCE TAB FOR THIS CARD?? .
PLEASE HELP ME OUT
IAM HAVING P3 450 ,WIN98SE , 128 MBSDRAM . AND LAPTOP OF P3 1200 WIN XP 512 RAM.
THANKS
Results 1 to 1 of 1
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56 -
WinTV-HD software needed (not HVR, PVR, Nova, but for original PCI card)
By cybertheque in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2009, 01:21 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppauge WinTV 2Go capture card was Kworld DVD Maker USB 2.0
By Vampire74 in forum Capturing and VCRReplies: 4Last Post: 19th Jan 2008, 10:59 -
Unable to capture from camcorder with WinTV-PVR 250 card and and WinTV2000
By forestial in forum Capturing and VCRReplies: 1Last Post: 29th Dec 2007, 20:00
