Try NordVPN to access Netflix or other streaming services from any country and also surf safe!
  1. devdev devdev's Avatar
    Sep 2003
    hi
    anyone know of video capture sw for pc win 10 that can be set with a set cut off point - say 3 hours for vhs?
  2. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    In VirtualDub, Capture -> Stop Conditions. Units are seconds, so 3 * 60 * 60 = 10,800.
    http://www.digitalfaq.com/forum/video-capture/7427-capturing-virtualdub-settings.html#post45242
    (Formerly vaporeon800)
  3. devdev devdev's Avatar
    Sep 2003
    Thanks so much
    Appreciated
  4. devdev devdev's Avatar
    Sep 2003
    would you happen to know what a good dv format i chose to capture to in virtualdub?
  5. if you capture 3 hours of content expect A/V desync. Focus on ~20min parts for best results
    DV codec are obsolete, focus on lossless codecs (lagarith, huffyuv or UTvideo); i recommend Utvideo (yv12 support and compress more if needed)
