Results 1 to 1 of 1
  1. So, this may be a topic more apt in this thread on this site: http://forum.doom9.org/showthread.php?t=125966
    However, I just registered, they won't let me post there yet, so I thought I'd give this place a try first.
    So, I would often capture raw Dolby Digital audio in PCM format with the AVerMedia Extremecap U3 and then convert it to bit-perfect AC3 with eac3to/BeSplit command line.
    Like so: besplit -core -input 1.wav -type ddwav -output 1.ac3
    Problem is, AVerMedia has gotten ridiculous with their copy protection to the point that the card that I've owned for 6 years has been rendered a brick.
    I've now put my faith in the Inogeni 4K2USB3 capture card which to its credit is a lot more seamless, howevere with the Dolby Digital sound aspect, something seems to be off.
    I should note that the old card recorded in 30fps and the new card records in 60fps so that may be a factor, I don't know.
    Here is the .wav file of the test recording, which sounds typical: https://drive.google.com/file/d/1IYVwyY1gL7wRn7gmqp8WGkmVuiiCS1tC/view?usp=sharing
    And here is the .ac3 file which is making sporadic noises rather than just having normal sound: https://drive.google.com/file/d/1n4m6LDXtUFrFZrMND0TqIFLsvZQyzmsK/view?usp=sharing
    So, is it the framerate? Is it the codec? Is there something I can change to make my conversions successful without buying a new card?
    And if I have to buy a new capture card, which USB capture card would work well with BeSplit?
    Thanks in advance to anyone who can help.
    -Arian
