I'm ripping my Thunderbirds DVDs to MKV using HandBrake and found the following:
Original DVD VOB file:
It looks like AC3 Dolby Digital 6 channels.Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Muxing mode : DVD-Video
Duration : 26 min 29 s
Bit rate mode : Constant
Bit rate : 448 kb/s
Channel(s) : 6 channels
Channel layout : L R C LFE Ls Rs
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Compression mode : Lossy
Stream size : 84.9 MiB (8%)
Service kind : Complete Main
In HandBrake, when I open the file for ripping, the default audio option is:
Track: Unknown (AC3) (5.1 ch) 448Kbps
Codec: AAC (avrcodec)
Bitrate 160
Mixdown: Stereo.
So I assume I would have to change this to:
Codec: AC3 Passthru
My amp has Passthru capabilities such as DTS, DTS-MA, etc.
I am thinking of adding another track in case I'm playing this file on a device without Passthru capabilities, the track would be:
Codec: AC3
Bitrate 160
Mixdown: Dolby Pro Logic II
I've tested the above on my AV setup and to me it seems to sound clearer and more "broad" when playing the AC3 Passthru track.
Am I doing this right?
+-- Julian Milano
Which is to be expected since 160 kBit/s for stereo AC3 is a low bitrate. Generally, 192 kBits/s is about the lowest I would do with stereo AC3. Below 192 quality drops dramatically.
Which brings the next question: Why AC3 for the stereo downmix? Why not AAC or even MP3? Both would be a better choice than AC3 if it isn't for some playback compatibility. -
No reason for choosing AC3, if you reckon AAC or MP3 is OK then i'll try that.
PS: I reckon the bitrate is 160 as this was probably the best they could do back in 1966!Last edited by JDMils; 13th Jun 2021 at 22:34.
+-- Julian Milano
A higher bitrate and number of channels can contribute to "higher quality" perception. AC-3 5.1 contains 6 independent, full-range channels for left, right, center, surround left, - right and subwoofer.
AFAIK a "2 channel Pro-logic downmix" will contain 4 channels. Three for left, right and center, and 1 (monoural) limited range channel for surround.
When such a downmix is needed, I'd stick to the original 448 bitrate to save as much "quality" as possible. You are going from lossy source to again lossy encoding. By all means, do try & find out for yourself. -
If your player can deal with it use AC3 Passthru That retains the original AC3 audio.
Note that AC3 wasn't officially added to the MP4 spec until a few years ago. Older Apple devices can't play AC3.Last edited by jagabo; 14th Jun 2021 at 20:51.
Converting DVD TV Series to MKV with subtitle option
By Sprogginz in forum DVD RippingReplies: 1Last Post: 1st Oct 2020, 08:10 -
Which Audio Track to Choose To Multiplex Down to STEREO?
By Pareto Optimal in forum DVD RippingReplies: 6Last Post: 22nd Aug 2020, 03:37 -
one audio language option vanished, in a dual audio track IN VLC mdia plyr
By jraju in forum Newbie / General discussionsReplies: 0Last Post: 28th Dec 2019, 06:43 -
DTS-HD Audio, ripping to mkv, help with what streams to rip, plz
By bar72 in forum AudioReplies: 4Last Post: 12th Nov 2019, 17:46 -
Ripping episodic DVD to multitrack (audio) MKV or MP4 files
By tonyaldr in forum DVD RippingReplies: 8Last Post: 15th Jun 2017, 14:12
![Computer details: [Desktop]
Windows 7 x86 Enterprise SP1
Intel Core2 Duo, E6850 3.0 GHz
C:\ = 1TB, D:\ = 5TB
[HP-DV7]
Windows 8 x64 Enterprise SP1
Intel i7, Q740 1.73GHz
C:\ = 750GB, D:\ = 750GB Comp](/images/buttons/computer.gif)
