Results 1 to 30 of 34
  1. Hello, I need help removing some dotcrawl, I've tested some plugins but these doesnt load in my avisynth+ 64 bits version, someone could help me?
    [Attachment 59357 - Click to enlarge]
  2. A simple convolution kernel often works. These are the settings:
    1 0 1
    0 1 0
  3. There's a 64 bit version of CheckMate. And with fuzzy VHS you can downscale the width and scale back up to reduce the dot crawl without hurting the sharpness of the video.
  4. Originally Posted by jagabo View Post
    you have the pluging? I have been looking for it and no one is working to me
  5. Originally Posted by johnmeyer View Post
    1 0 1
    0 1 0
    how I do it, could you explain to me please, I'm very noob in avisynth
  6. Originally Posted by johnmeyer View Post
    1 0 1
    0 1 0
    I get this error "general convolution : both luma and chroma cannot be set for subsampled video formats"
  7. Originally Posted by FelipeArchives View Post
    You can get it here: https://github.com/tp7/checkmate/releases/tag/0.9
  8. Originally Posted by jagabo View Post
    Thank you, I've tried it, but when I load the plugin and type "CheckMate" it doesnt apper, so I dont know why?
  9. when I type on avspmod "CheckMate" it doesnt apper or appers in red and error, even if I load the pluing in the begining
  10. Originally Posted by FelipeArchives View Post
    1 0 1
    0 1 0
    Add chroma=false:
    GeneralConvolution(matrix="0 1 0   1 0 1   0 1 0", chroma=false)
    Oops, I was playing with the matrix and posted the wrong one earlier.
  11. I don't know what the deal is with avspmod. But you should be calling CheckMate while the video is still interlaced. And it doesn't work as well with PAL as it does with NTSC. Typical usage: CheckMate(thr=10, max=20, tthr2=20)
    it says "checkmate works only with planar colorsapces"
  13. ConvertToYV12(interlaced=true) before CheckMate.
  14. Originally Posted by jagabo View Post
    It still doesnt load in my avisynth plugins
  15. FYI, there is a way you can feed TFM and MultiDecimate a list of frames you want to delete, and AVISynth will decimate those frames. I use Excel to handle the formatting for the two files you need (input.txt for TFM and mfile.txt for MultiDecimate).
  16. Originally Posted by FelipeArchives View Post
    What error message are you getting?
  17. Originally Posted by jagabo View Post
    it just dont appers when I recall "CheckMate", it appers in red and not in the pluings display menu
  18. What happens when you preview the script? Remove the call to Checkmate but leave the LoadPlugin() for checkmate in your script. Preview the script. Does the LoadPlugin give you an error message?
  19. Originally Posted by jagabo View Post
    when I load it no appers any error messages, but when I recall it to use the filter, it doesnt apper
  20. Originally Posted by FelipeArchives View Post
    What does "it doesn't appear" mean? What doesn't appear? I don't know avspmod well but from what I've seen if you don't get an error message in the preview window the script is working.
    Try using VirtualDub2 to view your script. Does that give you an error message?
  21. When I recall "CheckMate" in the lines, check the picture above, it appers in red and I cant use the filter or adjust it, It just load the pluging but not works
  22. All I can tell you is it works for me:
    [Attachment 59395 - Click to enlarge]
  23. Originally Posted by jagabo View Post
    yes in your works, I dont know why in mine no, any idea? could you share to me your avisynth with the plugins?
  24. Member
    Mar 2008
    Do you have checkmate.dll in the proper folder?
    Where did you put it?
  25. Originally Posted by davexnet View Post
    I load the pluging from the download folder, and also I've added it on the plugin folder, none has worked
  26. Member
    Mar 2008
    You're using the 64 bit version of AVSPMOD?
    Did you put the 64 bit version of checkmate.dll here?
    C:\Program Files (x86)\AviSynth+\plugins64+\
    Which version of Avisynth do you have installed?
    The other thing you can try is the 32 bit version of AVSPMOD, and the 32 bit version of checkmate.dll
    put in the 32-bit plugin folder
    If you click on Help/About you can check which version you're running:
  27. Thank you all for the help! now Its working!
