    Apr 2018
    Sunsari [Nepal]
    Hello Members
    I am trying to Watermark my videos using Batch Script,
    I Had Previously Created a .bat Files Which is almost Good
    and Now i am trying to add burn subtitle cmd but Getting error When i Run Batch File
    but i tried to print the final cmd, and When I Manually copy paste cmd and run then, it Worked For me
    Please Guide Me the exact issue, and How to Set subtitle Path on cmd
    I had added option to Crop (Top and Bottom)
    Please See Below
    @echo off
    set %1
    set /p x=crop on Top (px):
    set /p y=crop on Button (px):
    set /a z = x + y
    echo %z%
    IF NOT DEFINED Title SET "Title=encoded"
    :MENU
    SET /P M= Choose Quality : Press [1] :
    IF %M%==1 GOTO 480
    :480
    echo "C:\Users\Alone\Downloads\Video\Screenshots\ffmpeg.exe" -i %1 -vf "ass=subtitle.ass, crop=w=iw:h=ih-0%z%:x=0:y=0%x%, scale=720:-4" -c:v libx264 -b:v 375k -minrate 375k -maxrate 375k -bufsize 375k -preset medium -c:a aac -b:a 48k "%~dpn1-%Title%-480p.mkv"
    Pause
    exit
    But when i Directly Run Cmd then i am Getting Error
    Please Help me to Fix this issue
    Apr 2007
    Australia
    Hi.
    I did only 1 test. It worked for me.
    @echo off
    :: Output goes into the \New folder.
    if not exist New\ md New
    Title "%~n1"
    set /a z = x + y
    echo %z%
    :MENU
    IF %M%==1 GOTO 480
    :480
    "C:\Users\Alone\Downloads\Video\Screenshots\ffmpeg.exe" -i "subtitle.ass" -i %1 -vf crop=w=iw:h=ih-0%z%:x=0:y=0%x%,scale=720:-4 -c:v libx264 -b:v 375k -minrate 375k -maxrate 375k -bufsize 375k -preset medium -c:a aac -b:a 48k -c:s ass "New\%~n1-encoded-480p.mkv"
    Pause
    exit
    My preference would be:
    "C:\Users\Alone\Downloads\Video\Screenshots\ffmpeg.exe" -i "subtitle.ass" -i %1 -vf crop=w=iw:h=ih-0%z%:x=0:y=0%x%,scale=720:-4 -c:v libx264 -preset medium -crf 22 -c:a aac -b:a 128k -ar 48000 -c:s ass -threads 0 "New\%~n1-480p.mkv"
    If the cropping is the same for all your clips then I would set x : y only once, and then process all the clips in a folder.
    This requires several changes to your batch file.
    Perhaps this might be a better way to go.
    https://arccoder.medium.com/ffmpeg-add-a-logo-on-video-bf1f4652792a
    Cheers
    Last edited by pcspeak; 11th Jun 2021 at 18:35. Reason: Forgot the 'k' on audio bitrate :(
  3. Member Budman1's Avatar
    Jul 2012
    NORTHWEST ILLINOIS, USA
    Don't know if it was a finger check or not but the original example is missing the final quote after .ass
    Subtitles are fussy when i comes to double quotes, single quotes and escaping certain characters.
    Apr 2007
    Australia
    Hi Budman1.
    You're right, but as the whole filter string was enclosed in double quotes, it's ok. Well, that technique works here.
    I don't use the double quotes around filter strings as a rule. (As shown in the code in my previous post.)
    It's just another thing for me to get wrong.
    Cheers.
