I want to convert a dvd rip. is is 640x272, 24FPS. Someone please tell me the exact settings you would use. I have converted quite a few movie's before but never a DVD rip. I will use TMPGenc, if there is sometihng better to sue tell me. Thanks.
Only G O D can judge me.
sounds like it is almost NTSCfilm (23.976fps)Originally Posted by Perry2175
I would use TMPG, and the NTSCfilm template.
under settings, advanced, use 16:9 source, and full screen keep aspect ratio. I get good results with these settings and 640x272 files.
you could also use CCE for the increased speed/quality if you'd like, just make sure to run your file through pulldown after encoding to enable the pulldown on playback(TMPG has this enabled in the film template)
if you do use CCE, I would use avisynth with the following script:
avisource("c:\path\file.avi")
bicubicresize(480,360,0,0.75)
addborders(0,60,0,60)
resampleaudio(44100) #'crashfix' for athlons
this should give good results as well -
Just a little correction. Since the source aspect ratio is ~1:2.35 and not 16:9, resize as follows.
BicubicResize(480,278[,b,c])
AddBorders(0,96,0,106)
or
BicubicResize(448,260[,b,c])
AddBorders(16,108,16,112)
DVDrip Settings
By hardy in forum Newbie / General discussionsReplies: 4Last Post: 30th Nov 2011, 11:58 -
HC enc: Your settings ?
By themaster1 in forum RestorationReplies: 6Last Post: 21st Oct 2011, 20:55 -
Questions regarding recording settings and compression settings
By so in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2011, 08:45 -
Best Settings
By devdev in forum DVD RippingReplies: 2Last Post: 26th Jan 2009, 10:46 -
HD Settings
By kiwikiwi in forum EditingReplies: 9Last Post: 13th Dec 2008, 16:20
