I had a hp100i cd burner which I had no problem with.Sold it to my mate
and he can't select dma on the drive,Is mother board supports dma the hard drives are both selected,but everytime you reboot the tick as gone.
Not sure what motherboard it is but he is running Windows ME.
Any ideas on this? I have tried to help him but I'm at a loss now.![]()
Is he checking DMA in ME or the BIOS settings? Make sure the BIOS is set to DMA and then reset the Windows setting.
RG -
I had the same problem with my CDRW that is say only connected to the Primary IDE controller but not the secondary IDE. So I fixed that (in Win98) Device manager by selecting the Bus Master IDE Controller and under the options, select only apply to the Primary IDE Controller. AFter the reboot, the secondery IDE controller will be gone under the Bus Master IDE controller. You can thus select DMA on the CDRW and it will remain on even after reboot....hope this help.
Thanks for all your help, should be seeing him this week so I will give these a try...
Select subtitles automatically in a DVD
By dexter30 in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2010, 10:38 -
Can you enable DMA for an external DVD burner?
By Erasmus in forum DVD & Blu-ray WritersReplies: 9Last Post: 6th Sep 2009, 11:10 -
DMA changes to PIO for all 3 Dvd drives, even after unistalling IDE driver
By Denvers Dawgs in forum ComputerReplies: 3Last Post: 2nd Mar 2009, 15:45 -
How to take Two DVD's and Merge to One with Menus to Select
By videocheez in forum Authoring (DVD)Replies: 0Last Post: 31st Dec 2007, 18:50 -
DVD-ROM to DVD Burner Direct Burning
By Wilson7777 in forum DVD RippingReplies: 6Last Post: 15th Jun 2007, 12:37
