Test your bottlenecks.
If you have an upstream bottleneck in the avs script, nothing you can do will speed up vdub2 downstream. e.g If the avs output is 10fps max, then vdub2 cannot go faster than 10fps
Adjust your script and vdub2 settings. You can use avsmeter as a diagnostic aid. Maybe some of your settings are not optimized, eg. wrong prefetch number
If vdub2 or some codec is your bottleneck, use faster settings. e.g. if some encoding settings are very slow and the bottleneck, use faster settings
remultiplex audio with VDub2 while Avisything?
By taigi in forum AudioReplies: 0Last Post: 5th Jun 2021, 11:07 -
Any Faster Way for De-interlacing Using QTGMC?
By dellsam34 in forum Video ConversionReplies: 93Last Post: 23rd Dec 2020, 20:05 -
Strange conflict with vdub2 internal lagarith codec and independent one
By mammo1789 in forum Video ConversionReplies: 0Last Post: 30th Nov 2020, 15:40 -
Does encoding in Handbrake without Audio make the encode faster?
By focuspuller in forum Video ConversionReplies: 10Last Post: 11th Jan 2019, 05:18 -
iMovie faster than tmpgenc
By Nick123 in forum EditingReplies: 2Last Post: 6th Mar 2018, 17:58
