Hi all, I'm trying to use Ffmpeg to apply a Lut and re-encode a file at a lower resolution. This is my command line:
"C:\mabs\local64\bin-video\ffmpeg.exe" -i "F:\Videos\2021_06_03_Swanage\Beach_run_Orig.m ov" -vf "lut3d=F:\Videos\2021_06_03_Swanage\Beach_run_Inst a360_LUT.cube, scale=1920x1080:flags=lanczos" -c:v libx265 -crf 22 -preset slow -an Beach_run.mov
[Edit: when I view this on my phone, there are line breaks and a space in mov - obviously that's not there in the real thing]
Sadly, it has a problem applying the LUT. In case it was the LUT, I tried a 3dl (or whatever) and that didn't work. I'm not at home so can't post the error, but thought I'd post now in case there was something wrong with my command line usage that was obvious. I'll post the error in a follow up, but any help please would be most appreciated.
Edit: here is the error message:
[lut3d @ 0000024b736613c0] [Eval @ 000000536c1fe140] Undefined constant or missing '(' in 'Videos2021_06_03_SwanageBeach_run_Insta360_LUT.cu be'
[lut3d @ 0000024b736613c0] Unable to parse option value "Videos2021_06_03_SwanageBeach_run_Insta360_LUT.cu be"
[lut3d @ 0000024b736613c0] [Eval @ 000000536c1fe060] Undefined constant or missing '(' in 'Videos2021_06_03_SwanageBeach_run_Insta360_LUT.cu be'
[lut3d @ 0000024b736613c0] Error setting option interp to value Videos2021_06_03_SwanageBeach_run_Insta360_LUT.cub e.
[Parsed_lut3d_0 @ 0000024b72f5e180] Error applying options to the filter.
[AVFilterGraph @ 0000024b73661c00] Error initializing filter 'lut3d' with args 'F:Videos2021_06_03_SwanageBeach_run_Insta360_LUT. cube'
Error reinitializing filters!
Failed to inject frame into filter network: Invalid argument
Error while processing the decoded data for stream #0:0
Solved! I needed to escape the : and use forward slahes, and use ' when defining the path for the LUT:
"C:\mabs\local64\bin-video\ffmpeg.exe" -i "F:\Videos\2021_06_03_Swanage\Beach_run_Orig.m ov" -vf "lut3d='F\:/Videos/2021_06_03_Swanage/Beach_run_Insta360_LUT.cube', scale=1920x1080:flags=lanczos" -c:v libx265 -crf 20 -preset medium -an Beach_run_ffmpeg.mov
I found it here: https://stackoverflow.com/questions/58659222/ffmpeg-filter-complex-lut-file-path-givin...ems-on-windows
Please help me get ffmpeg's sws_dither option working
By Videogamer555 in forum Video ConversionReplies: 6Last Post: 14th Dec 2023, 15:56 -
Audio rate not working ffmpeg
By Budman1 in forum Video ConversionReplies: 2Last Post: 28th Sep 2019, 15:13 -
ffmpeg help not working
By loa909 in forum Newbie / General discussionsReplies: 7Last Post: 9th Jul 2018, 12:40 -
ffmpeg drawtext not working
By vhelp in forum ProgrammingReplies: 21Last Post: 5th Feb 2017, 21:34 -
Ffmpeg with http proxy not working
By Karol in forum Video Streaming DownloadingReplies: 2Last Post: 23rd Nov 2016, 09:22
