I using the following .bat file to remove all metadatas, but it does no remove all of them.
It does not remove all metadatas like _STATISTICS_WRITING_APP. I would like to know how could I remove all the metadatas and keep the subtitles and audios.PHP Code:echo off
mkdir outputs
for %%a in ("*.mkv") do [url=https://www.videohelp.com/software/ffmpeg]ffmpeg[/url] -hide_banner -i "%%a" -map 0:v:0? -map 0:a? -map 0:s? -c copy -map_metadata:g -1 "outputs\%%~na.mkv"
pause
PHP Code:General
Unique ID : ......... (....)
Complete name : Secrets.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 581 MiB
Duration : 51mn 30s
Overall bit rate : 1 578 Kbps
Writing application : Lavf58.76.100
Writing library : Lavf58.76.100
NUMBER_OF_FRAMES : 436
NUMBER_OF_BYTES : 15266
_STATISTICS_WRITING_APP : [url=https://www.videohelp.com/software/MKVToolNix]mkvmerge[/url] v57.0.0 ('Till The End') 64-bit
_STATISTICS_WRITING_DATE_UTC : 2021-06-05 14:58:10
_STATISTICS_TAGS : BPS DURATION NUMBER_OF_FRAMES NUMBER_OF_BYTES
DURATION : 00:47:34.083000000
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L4@Main
Codec ID : V_MPEGH/ISO/HEVC
Duration : 51mn 30s
Width : 1 920 pixels
Height : 960 pixels
Display aspect ratio : 2.000
Frame rate mode : Constant
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Writing library : x265 3.0_Au+14-c7e5878bdd31:[Windows][MSVC 1916][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=4 / numa-pools=16 / wpp / no-pmode / no-pme / no-psnr / ssim / log-level=2 / input-csp=1 / input-res=1920x960 / interlace=0 / total-frames=74167 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=24 / keyint=250 / gop-lookahead=0 / bframes=8 / b-adapt=2 / b-pyramid / bframe-bias=40 / rc-lookahead=80 / lookahead-slices=4 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / splitrd-skip / rdpenalty=0 / psy-rd=0.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=1200 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=0.80 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=0 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / max-cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / no-hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=10 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / qp-adaptation-range=1.00
Default : Yes
Forced : No
Audio #1
Format : AAC
Format profile : HE-AAC / LC
Codec ID : A_AAC
Duration : 51mn 30s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz / 24.0 KHz
Compression mode : Lossy
Delay relative to video : 31ms
Language : German
Default : No
Forced : No
Audio #2
Format : AAC
Codec ID : A_AAC
Duration : 51mn 30s
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Language : German
Default : No
Forced : No
Results 1 to 1 of 1
batch merge videos and audios with ffmpeg
By m0ck in forum Video ConversionReplies: 6Last Post: 27th May 2021, 09:12 -
ffmpeg remove metadata
By osmium in forum EditingReplies: 2Last Post: 18th Feb 2020, 13:57 -
How to remove Complete Metadata from video file
By deepfrayder in forum Newbie / General discussionsReplies: 9Last Post: 19th Aug 2019, 07:58 -
How can I remove a single metadata from an MP4 file?
By aveceux in forum Video ConversionReplies: 2Last Post: 26th Feb 2019, 10:36 -
Please recommend freeware to remove image metadata
By hamilton accie in forum Newbie / General discussionsReplies: 2Last Post: 2nd Aug 2017, 19:47
